Question about Microsoft Xbox 360 Console
Wireless headset Since getting the console back in late June, we have gone through like 4 wireless headsets. They keep failing (dead). We try and plug them in to restore them, but no such luck. Any ideas? Thanks, Cadman
  • Romo117 Jun 19, 2008
    my headset died two days ago :( it just wouldnt charge or turn on
    what can i do
    Problem Solver:
  • 4 Answers
Do you mean the console will not sync with the wireless headsets? if so, on the console is a lil white button near the memory card insert points, and there is also one of those lil white button things on the wireless headsets. On the headset, it is near the end that is closest to your mouth. Press and hold both of them for a few seconds (like 3s) and i usually point my wireless headset towards the console and wait for them both to flash the player "1" lights on the console and headset.
Posted on Sep 20, 2007
SOURCE:
On my XBOX 360 I am getting a crackling noise in my headphones when I have my microphone plugged into the wireless controller. I have tried two other known good controllers and the problem is still p
This sounds like it is probably an issue with your wireless controller. If there is any way for you to safely blow into the tiny hole that you plug your headset into in an attempt to clear any dust or debris from that area it would be in your best interest.
If not, try a third headset-- the same issue means either play without a headset or purchase a new controller.
Hope this was helpful!
Jan 30, 2012 | Microsoft Xbox 360 Console
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Headset pairing code
First, try '0000' (four zeros), which happens to be the most common code chosen by headset manufacturers. If it doesn't work, switch to '1234'. In case it keeps failing, try '8888'.
Hope one of these codes works for you.
Cheers! Carlos
May 19, 2010 | Nokia Bluetooth Headset BH-207 Wireless...
PS3 Bluetooth® Headset Wireless Headset: i need a pass key for my bluetooth headset model #...
First try '0000' (four zeros). If it doesn't work, switch to '1234'. It it keeps failing, try '8888'.
Hope one of these codes might suit your case.
Cheers! Carlos
May 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
PS3 Bluetooth® Headset Wireless Headset: lost my pass key...
Cheers! Carlos
I am getting feedback and an echo in my Plantronic CS55 wireless
Had similar issue.
This how I fixed it
1) set bottom mic to A
2) set dial on the side of CS55 to "Setting 1" most typical
3) set sound lever on the back to "1"
4) played with mic control on the back until quality became sufficient
Jun 26, 2009 | Plantronics CS55/HL10 Wireless Office...
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Turning on headset freezes wireless controller at times
one of the best wireless headsets on market is a jabra.its the one they sell with warhawk for £40. otherwise you can pick one up for around £20....
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
69 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
