posted by musicbox on Aug 25, 2007
I am having a problem with the hotsync. It worked the last time I tried it in July. Now I get an error message saying that it cannot establish the connection to my desktop. I have Windows 2000, there is no icon on the lower right of my computer.
Help--I am not very computer literate. thanks, Musicbox
Comment by musicbox, posted on Aug 25, 2007
How do I do that? ( check for active security under the workpad.?) Thanks, I really am not too computer literate--musicbox
I am not sure how to check for active security under the workpad--please let me know how to do this. step by step. THanks, Musicbox
Comment by musicbox, posted on Aug 27, 2007
I have not changed anything that I know of. I looked in control panel and saw a lot of HotFix programs that I could not remove --something related to window--I removed them, finally, but still no go. What do I clean the connectors with? ( I wiped them with a cloth--use any solvent?--Thanks, musicbox
1 Other User Has The Same Problem
Comment by nkelvin, posted on Aug 07, 2008
I have had a C3 since 1999 and I have alwasy been able to hotsync as computers then had serial ports. I've now got a new computer that doesn't have serial port. So I bought a USB-serial connector. However, the computer doesn't have COM1, COM2, COM3 , COM 4 available, but has higher numbers like COM7. Is there any software fix to allow one to select COM7 in the hotsync setup? Regards, Norbert
Best Solution
Please check if you don t have any security active under your wordpad.
That might block you activesync conection
Comment by sergioems, posted on Aug 25, 2007
You have not changed anything since the last time you conected in july to now days? if not there could be a conection problem. try to clean all conectores in the c3 and in the cradle. let me know results
Comment by sergioems, posted on Aug 27, 2007
use alchool
Rating Locked! (?) musicbox has rated this solution as Thanks for Trying
Can you Help with these PDAs problems?
Repair Service
Find PDA Repairman Near You:
