Question about Fujitsu Siemens CELSIUS Notebook
Notebook Keyboard, some Keys doesn't Work. Replace the entire Keyboard??
I have a Swiss made Laptop and the Keyboard is malfunctioning. The upper and middle Keys are working properly but the down Keys like "Y" "B" "Space" "Left" "Upp" and "Right" doesn't work at all. Some down Keys like the "Down" and "M" are also working properly. Is it the Keyboard that needs to be changed or what else could cause this malfunctioning? Thanks.
  • Picas Aug 27, 2007
    Does anyone know hoe to repair Keyboards? Is that even possible?
  • marie222111 Jun 27, 2008
    som keys don't work after i spilled a small amount of liquid,i use onscreen keybord now,
    eg if i press e on shows d3
  • 55 Answers
Remove the keyboard and check if the cable is plugged into the laptop correctly which is usually not the case. Usually the keys may have been damaged and you may have to buy a keyboard replacement.
Posted on Aug 25, 2007
SOURCE:
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Compaq cq60 keys not working
The keyboard maybe faulty.
Connect an external keyboard to youe laptop and if all the key work on this keyboard then most like the laptop keyboard is faulty.
If this external keyboard also malfunctions then the keyboard controller chip on the laptop motherboard is faulty and it would not be worth repairing as this is an old model laptop.
Mar 04, 2012 | Compaq Presario CQ60-212US Notebook
Compaq CQ60 some keys not working
My acer aspire one notebook keys a; f,g; j ;l are not working help me to fix.
keyboard malfunction, it must be replaced - a job best left to a repair shop.
Sep 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
SHIFT KEY FOR HP PAVILLION FELL OFF HOW TO REPLACE PLEASE
I am sorry to inform you that this issue is hardware malfunctioning of the keyboard. The laptop keys are inter related to each other. So there is no option to fix the single key for your notebook. You need to change the entire keyboard of the notebook.
Jun 10, 2010 | HP Pavilion dv9000z Notebook
Dead keys on the keyboard of a 2000 Cisnet laptop; what can I do to fix?
Contact the manufacturer and order another keyboard.
(If under warranty, just have it replaced rather than ordering one).
Good Luck :)
Mar 14, 2010 | ZT Group Cisnet T2060 Notebook Computer
Toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Feb 10, 2010 | Toshiba Satellite A215-S5837 Notebook
Trouble with keyboard/space bar sticking and few keys. how to solve
I would take a butter knife and pop off the keyboard, clean it out, make sure the two metal objects are aligned and pop it back in.
Thanks,
Brandonmxb
Dec 11, 2009 | Acer Aspire 3610 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Fujitsu Siemens CELSIUS Notebook Logo
824 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
