Yes, I have a pasquini livietta t2 only 6 months old. The steam wand only has a stream of water no steam. What could this problem be? The wand is not clogged.
SOURCE: No steam - steam jet does not heat
1. Turn off and unplug the machine.
2. Wait 2 hours.
3. Remove the water tank.
4. Remove the top cover. (Two screws in the top)
5. Remove the back/side cover. (Two screws along the top crimp)
6. Locate the thermocouple.
6.a The thermocouple is on the left side of the machine, on the back side of the heater block. It's a small pin with a plastic knob on it.
7. Press the pin on the thermocouple in.
7.a. If the thermocouple is not out, pull it out and press it back in.
SOURCE: I own a vintage Pasquini Livietta cappuccino maker
Remove the shower screen and make sure it is clear, then remove the screws on the top panel, If after checking screen problem still occurs, find the tube that leads to the head and make sure it is not blocked.
SOURCE: My pasquini livia machine is
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
Boiler end gasket
11
Expanse Valve
21
Group gasket
Heating element
12
Drain
22
Refill solenoid
Gasket for above
13
Pressurestat
23
Group touch pad
Steam + water valve
14
Main switch
24
Drip tray grill
5
Pop off valve
15
Group
25
Water flow meter
6
Bleed valve
16
Group solenoid
26
Drip tray
7
Water level Probe
17
Group handle
27
Basket
8
Auto refill relay effect
18
Filter basket single
28
Steam-water valve knob
9
Heater exchanger injector
19
Plastic gasket
29
Manual refill valve
10
Heat wand
20
Site glass
30
Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
