Question about Fujitsu Siemens CELSIUS Notebook
Display Disassemblage Help Notebooks
Do you have any usefull Tips for Display disassemblage on Laptops? I need to change the Backlight on 3 different Laptops and maybe the Inverter too, could you give me helpfull Tips? Mostly i would like to know how to check the Inverter to make sure it doesn't need to be replaced too. Do i have to let the Laptop ON to check if it is receiving and giving out 12 volts to the Backlights? Any Help with this would be appreciated.
  • Picas Aug 27, 2007
    Thanks for that jmorgan!!
сасать твари!!!! АМЕРИКАНСКИЕ
Posted on Nov 09, 2008
Hello Sellar,
Am tony Auditch from uk i need your items for my Wife in west African so i want you to send me the total cost of the item+ the shipping cost. here is my Email [email protected] [email protected]
tThinks
Posted on Sep 04, 2008
    Brigadier General:
  • 6,966 Answers
Hi, The inverter puts out a high frequency, high voltage supply to the CCF (florescent tube). It's output would then be high freq AC. My suggestion for the disassembly of the front panel display would be the same as to your other post > http://www.fixya.com/support/t187232-stripes_display_way_repair Cheers.
Posted on Aug 25, 2007
    President:
  • 317 Answers
Check this page: http://www.fonerbooks.com/laptop_5.htm
SOURCE:
My lcd display is dim on my sony xdr-ds12ip dab radio, you can see the display faintly and it does search and display the time. Also the backlight is working normally.
The backlight allows you to see the display. The LCD display only allows the backlight to shine through and produce the characters. Try looking at the display from a different angle as the light is polarized.
Jan 29, 2015 | Sony Computers & Internet
Como desarmar un mini split carrier
You tried three notebooks, but did they have the same video adapters? Try a notebook with a different video adapter. i would say your video adapter isn't good enough to put out a dual display. you might need to get a laptop with a better video card
Jan 23, 2014 | NEC Office Equipment & Supplies
Disassemblage a subwoofer Mordaunt Short
Normally in a sealed box, remove the loudspeaker first.
May 22, 2010 | Mordaunt Short 309W Subwoofer
Display
your laptop display mass color, it is not the issue of inverter.
there are two situations:
1) mass color you can not see any messages like letter or picture
2) mass color with some or any messages you can see.
above situations you need to check LCD sreen cable connection between LCD socket and the motherboard socket, plug back properly.if not fixed, there are some tips you may consider:
1) change the Ram if the display ram is not isolated.
2) the LCD cable damage need to change or
3) LCD screen damage need to change or
4) finally the motherboard display chips damage(rare)
May 07, 2009 | HP Compaq Presario V2000 Notebook
Black
If you're talking about you're notebooks display screen try connecting a standard monitor to you're notebook. There is a 15 pin VGA connector on the back of the notebook. Once connected restart the notebook. If you still do not have display on the monitor than you're integrated video card could be bad. If you do have display on the monitor, than you're notebooks video card is good needs to be repaired.
Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 28, 2008 | Acer Aspire 5100 Notebook
Monitor has gone completely black
Hi
Normally notebooks last abt 3 years (3.0 GHz is abt 3 years, sorry) and then you will have to upgrade or change. In this case I suggest you get the "monitor" changed to a used one (I think u can find it in ebay) or buy a new one. The approx cost is USD 300.00 depending on the make of your notebook. U could also get it repaired if u can find a technician.
May 20, 2008 | Computers & Internet
Dirty lense
To clean the lens accessing directly to the lens pick up you will need to disassemble the Nintendo. This operation invole risk of further damage to your WII, particularly if you are not exeperienced in servicing electronics. My suggestion is the following.
First try cleaning it with a dvd cleaner and cleaning solution, this operation involves no risk.
Check also if you are covered by guaranty, and eventually contact Nintendo to have your WII serviced.
If you want to proceed in opening the Wii, here are videos showing disassemblage procedure.
My strong suggestion remains not opening the Nintendo by yourself, unless you have done this many times on different devices.
Regards
May 19, 2008 | Nintendo Wii Console
LCD display
Could be a lot of things: here is general tips for no backlight:
First if there is a suspend switch (usually right below the LCD sticking out of the notebook) make sure its not pushed down.
second: Did the LCD have a red tint before it failed? if not its probably the inverter. If it did then its probably the backlight, but its best to test the inverter using a known good LCD first.
If you dont have one, then any repair shop that deals with laptops4.gif should be able to diagnose this pretty quickly (you shouldnt pay more than a 1/2-3/4 hour labor to take apart and diagnose.
if it really needs a backlight, it is a very difficult thing to replace the backlight - i see more people break the screen or electronics on the LCD trying to replace a backlight. always try an inverter first which is only about $20-$50 for the dells.
Its usually comparable in cost to buy an LCD ($100-$200 for the part on most models) than replace the backlight (150-220 is the typical labor charges i have seen. Just find out the part number of the LCD to match up a replacement. Try Bliss which sells screens on ebay - nice company to deal with and has a wide variety of screens,
http://stores.ebay.com/BLISS-COMPUTERS-LCD-SCREEN-STORE
Hope this helps!
Dec 20, 2007 | Computers & Internet
Can't find a repair/disassemblage guide for any FujitsuSiemens Laptop, specially Celsius H P4 Mobile
Just get the full manual of 102 pages, from (www.fujitsupc.com/www/content/pdf/usermanuals/CELSIUS/CELSIUS.pdf It is pdf file and if you can't dowload it give me your email and i will send it to you. it is 1.5mb. all the best:
Aug 25, 2007 | Fujitsu Siemens CELSIUS Notebook
Fujitsu Siemens CELSIUS Notebook Logo
81 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
