Back to:
Tags:
JVC TH-A10 System
JVC TH-A10 Won't TUrn on...
posted by sliggles on Aug 25, 2007
I had this system for almost 10 years now and I've been very pleased with it's quality and stability. I just moved into a new house and hooked it up. Everything was perfect until I was playing with the light switch. I forgot that it connected to the power outlet of the living room so that if you turn off the lights the power outlet goes out as well. For this light switch there's a sliding switch wher you you can dim the lights or make it brighter. As I was trying to dim the lights, everything, Tv included, shut off. I made the lights bright again and only the TV turned on. My JVC system was dead. Haven't been able to turn it on for a day. What kind of problem is this and how should i fix it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 20, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JVC TH-A10 Won't TUrn on...:
I don't want to Accept this solution
Can you Help with these Home Theater Systems problems?
one day i tried to turn on my stereo and it didnt come on...
DVD Player currently locked in to region 4 (Australia). Is...
My panasonic SA-HT700 dvd player/home theater system will...
JVC TH-A10 System
My JVC TH-A10 worked fine this morning. Now it won't turn...
JVC TH-A10 System
sub woofer cuts off like a breaker tripping when tha...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
