Question about EliteGroup P4VMM2 Motherboard
Ddr ram for my motherboard
Can i use a pc266 or pc333 513mb ram instead of what stated from the manual which is pc2100
    Scholar:
  • 76 Answers
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 25, 2007
SOURCE:
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
Need to install PC2100 DDR 1GB ram upgrade
The PC2100 DDR should be fine on that board. Each slot (which there are 3) will hold 1 gb of ram each. So finding 1GB PC2100 isn't the easiest, you can find 512mb, and put 1 512 in slot 1 and 1 in slot 2, There you'll have your 1GB.
Good Luck,
Don't forget to leave a rating.
Thanks
Mark
Mar 17, 2010 | EliteGroup L4S8A2 Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Jul 22, 2009 | Intel Motherboard
Is pc266 memory the same as pc2100
PC-2100 is the same as DDR 266MHz - you'll need to be sure it's the right number of pins/contacts on the DIMM though.
Mar 30, 2009 | AOpen MX4LR (91.89Y10.002) Motherboard
Can i use DDR 2 RAM for U8668d ver. 6.1 motherboard of 1GB
your motherboard uses DDR1 SDRAM PC2100 max. as stated on their website:
http://www.biostar-usa.com/mbdetails.asp?model=u8668+d
you cannont put DDR2, but you can expand up to 2GB
Hope this helps
Alex
www.CAS411.com
Mar 17, 2009 | Biostar U8668D (802700113338) Motherboard
Memory chips
You can use PC2100, see below for example http://www.amazon.com/Memory-Upgrade-PC266-PC2100-AA32C12864-PC266/dp/B00009OYBA
Sep 21, 2007 | Intel Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
160 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
