Question about RCA P52921 52" Rear Projection Television
RCA P52920BL My RCA 52" rear projection tv tries to turn on a couple of times, but doesn't. This started as an intermittent problem. Model # P52920BL, chassis 829351257...At first the set would turn on, but after a minute would shut down then restart. Did this a couple of times then stayed on....Then one day it tried to turn but wouldn't. Help Me...Henry
  • onsht1kll Jan 20, 2008
    Have the same problem except the one i'm trying to fix is the RCA P52921YX2, started out as interm turning off, now won't turn on, when pressing the power button the tv tries to turn on, you hear a short buzzing sound, then the tv will try to turn on 3 more times with the buzzing sound, then the tv stops trying. Different blogs have said to replace the flyback (don't use a generic one), then some say don't worry about the hor. deflection circuit some say it needs to be checked. Would it be worth buying(downloading) the service manual? Chassis no PTK195MB
    Thanks in advance.
    Problem Solver:
  • 13 Answers
I'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Posted on Aug 25, 2007
2 Suggested Answers
SOURCE:
MikeNJ1964
  • 398 Answers
SOURCE: tv
see other post.
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
SET TRIES TO TURN, BUT DOESN'T
The RCA P52920BL uses the PTK195 series chassis. The most common reason for the set not turning on is a shorted flyback transformer. To check this, measure the B+ when the set is plugged in - it should be around 145 volts. When you turn the set on, see if the B+ drops down at all. If the flyback is shorted, the set will try to start but the flyback draws too much current. The microprocessor senses this and immediately shuts the set back off. To confirm, unsolder the jumper wire bringing B+ to the flyback and put a 100 Watt bulb in its place. Turn the set on and if the flyback is shorted, the set will now stay on but the bulb will glow as bright as if it was plugged into the wall. If this is the case, replace the flyback. Let me know what you find and we will take it from there.
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
TV WONT TURN ON
try unplugging and plugging back in but wait 2 minutes in between. this will reset it.
Nov 14, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection P52920BL no volume, if you turn it up can hear speaking chirping
check the back of set to see if there' an internal external speaker switch- also check on screen audio menu to see if speakers are set to off
Oct 18, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Tv will not stay on
there is nothing you can do but get rid of it
Dec 26, 2008 | RCA P52920BL 52" Rear Projection...
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Dec 30, 2007 | RCA P52920BL 52" Rear Projection...
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA P52921 52" Rear Projection Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
