Question about Panasonic PV-GS39 Mini DV Digital Camcorder
Reset My camera is less than a year old and it was working fine until a couple of weeks ago when it started. I turn it on and it stays on for 5 seconds and says i have to reset,keeps doing the same thing over and over.
  • Anonymous Nov 27, 2007
    Same issue with the PV-GS300
    Problem Solver:
  • 18 Answers
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Posted on Feb 04, 2009
  • 69 Answers
Here is what I was able to find about your issue with your camera. [PUSH THE RESET SWITCH] is displayed. ? An irregularity in the Camcorder has been automatically detected. Remove the cassette or the card for data protection and then press the [RESET] Button with the protection on the Lens Cap. The Camcorder will be activated. ? An irregularity in the Camcorder has been automatically detected. Remove the cassette or the card for data protection and then press the [RESET] Button. The Camcorder will be activated. ? If you do not press the [RESET] Button, the power to the Camcorder is turned off automatically about 1 minute later. ? Even after you press the [RESET] button, the indication may still appear repeatedly. If so, the Camcorder needs repair. Detach the power connected, and consult the dealer who you purchased the Camcorder from. Do not attempt to repair the appliance by yourself. Here is the location of the reset button: 1 Open the LCD Monitor 2 Undo Grip Belt end and pull Lens Cap Cord downward to loosen Grip Belt. 3 Use projection on the Lens Cap to press the [RESET] Button . If this doesn't work here is the link to the site that I found this information on. http://www.indiana.edu/~libugls/equipment/pdfs/PanasonicPVGS29.pdf It is located on page 78 of the pdf file. Good Luck!!!
Posted on Aug 25, 2007
SOURCE:
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2014 | Water Heaters
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Old Practica SLR camera shutter not working
I have a practica mtl 50 with a couple of extra telephoto lenses if interested.Very good working comdition.
bob
[email protected]
Sep 06, 2009 | Nikon F2AS Photomic 35mm SLR Camera
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
I've had my camera for about 3 years now and have never had any problems until a couple of weeks ago. When I turned the camera on, it forced me to reset date/time and would occasionally show aperture 00...
Try getting new trusted brand batteries like duracell, And also if it forces you to change the D/T just change it. Also try getting a new memory card. (trusted brand). If none of this works then there might be a prob. Maybe someone dropped it. Try asking the company 2.
Hope this helps
Jun 26, 2009 | Canon Digital Rebel XT / EOS 350D Body...
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
DSC W55 Error code E:91:01
I've had the camera for about 2 years. Have had this problem twice. All I've done is follow the manual to reset/initialize the camera's original settings. After that it works pretty good.
Mar 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Panasonic PV-GS39 Mini DV Digital Camcorder Logo
473 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
