Question about SanDisk Sansa e250 MP3 Player
Songs show up even when deleted
I deleted a few songs but the names keep showing up. i had recorded something and put that song fromt he record folder in the song folder. two names showed up. for example, i had a pinao cover of linkin park. it showed up as "leave out all the rest" and another file as "leave out all the rest.wav" i deleted the song but the ".wav" one still appears on the list.it throws the order of my songs off. for example. when i choose "numb" it gives a song three titles down. how can i fix this problem?
  • 8,596 Answers
Disable Auto-Sync in Windows Media Player
Posted on May 26, 2008
SOURCE:
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Deleted songs from sansa e260 still show up on the menu
Turn the player off.
Push the HOLD button to the locked position.
Press and hold the RECORD button while connecting to PC.
Let go of RECORD button when you see Welcome to Recovery Mode on the player's LCD.
You are now connected in, you guessed it, Recovery Mode. Open My Computer and you will find a new removable flash drive labeled, 16MB-FORMAT.
DO NOT ATTEMPT TO FORMAT THE 16MB-FORMAT VOLUME!!!
Open the 16MB-FORMAT volume in My Computer and create a new folder on the drive in its root directory. Name the folder sansa.fmt, use the Safely Remove Hardware icon in the system tray, and disconnect the player from the PC. The player should now format itself. If all goes well the format will be successful. If not, I suspect you might have a defective internal memory module. If it is defective, you can replace it with one from another v1 or Rhapsody model unit. You can often find defective players on eBay for parts. The memory module from the e250, e260, e270, or e280 will work just so long as its from a v1 or R model.
Aug 28, 2009 | SanDisk Sansa e260 MP3 Player
Not letting me add songs
Very cool
ok so i called 1-866-sandisk and she told me how to fix it. you just flip the key lock at the top so you see orange, then hold down the record button. then you should get some sort of message on the screen. then you plug it in and under my computer a file should show up. you open it and make a folder in it called sansa.fwm (i think thats the right folder name, if not, try sansa.tmp or email me). then you unplug it and it should say formatting or something like that. once its done it should work.
Dec 30, 2008 | SanDisk Sansa E280 MP3 Player
Cannot get my computer to recognize my sansa e260 player
hey download real media player...itz easy to use and it ll show up ur sansa player and u can edit the song name list in it ..try out.. there u can just rite click and delete the songs in the real media itself...the song 'll shoe up in the libraray
Aug 17, 2008 | SanDisk Sansa e250 MP3 Player
Delete unwanted recordings on my MP3
-Plug your mp3player in
-Open My Computer
-Look for the folder with the brand name of your mp3player and open the folder
-Go into Recordings or something like it
-Select a song and press Delete
Good Luck.
Feb 25, 2008 | iLO (2 GB) MP3 Player
Deleting all recordings and some songs
first you go to songs and then go down to recordings, when selecting it you can delete them. also to delete some songs you should hook it up 2 da computer and take it out the music folder.
Jan 28, 2008 | Audio Players & Recorders
Software is deleted
my mp3 players software is deleted when i was downloading songs.now when i put the player to my computer it doesnot show the folder(drive)which previously was present.after this happended my player shows written in it disc error whenever i try to play the mp3 player.but the fm radio is working .so if you coukd assist in solving this problem
I need to know the website address for my logik mp3 player and voice recorder so i can download and reinstall its software. i can't find it
Dec 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
New folder opened automatically - I annot delete those folders...alls songs are gone
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 27, 2007 | SanDisk Sansa e260 MP3 Player
I cant find the songs to delete and it the refresh database fails everytime
If you cant see it in MTP mode, the MTP drivers may not be installed on your computer.
Its easier to do this than explain the other solution.
Follow these instructions and you will be back in business.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Cant Delete
well putting songs on your MP3 player is easy its taking them off thats the problem, so here are some easy steps to doing so. 1. plug in your MP3 player to the computer (USB) 2. go to my documents 3. scroll down to other 4. click sansa m230 5. click TCNANDO 6. then you have an option of Albums, Music,and RECORD click on Music 7. then you have the artists names and all you have to do is click the artist, then the album, and the ones you dont want you right click it and select delete 8. repet that until done deleteing songs of your choice 9. now you can add songs
May 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
