Question about Maytag PDB3600A Built-in Dishwasher
It hums, but doesn't pump or wash
Hi Folks, We have a Maytag Performa PDB3600AWE since a couple of years. A couple of days ago it decided to go on strike. Water is sitting in the tub at. And I turn the dial the lights for delay and heat come on when they are supposed to come on. However the motor just makes a humming noise. Does anybody have an idea what that might be? The serial number is: 1046 4653 ZH Thanks in advance for your help, Washdisher
  • 1 more comment
  • washdisher Aug 25, 2007
    Hi Krazytech,
    Thanks for your input. That's what I already feared. The float switch moves very easily and I was able to turn the motor by hand (with tool in my hand ;-)
    The microswitch underneath the floating part of the float switch seems to work as well.
    Thanks,
    Michael.
  • HE_OFFICER Nov 17, 2007
    I have the same problem. I shut the dishwasher door and the timer hums along like evering is fine, but the motor isn't running and no water is put into the tub. I'ven checking the continuity of everything I can get my hands to and ething seems fine. I'm about to go out and buy a new washer :(
  • Anonymous Mar 19, 2009
    I have a white build up all over everythng. look like calcium deposits. We tried a cheep brand of soap and start shortly after. we think there is something in the soap ther clogged everything. I took thinks apart and sure enogh every hole in every sprayer was clogged.
  • 725 Answers
You may have a bad motor. I would check the float switch it is the round hat looking thing on the left side. it should move up and down easy.. you may need a repairman to change out the motor/pump..let me know thanks
Posted on Aug 25, 2007
SOURCE:
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
Performa washer hums--stopped mid cycle, wont pump or agitate
Hi
Thanks for using FixYa. You are right the issue is with the motor; don’t think it’s related to a capacitor. The hum sound that you hear is from the motor which is trying to run however is unable to so you’ll need to check the pump and motor and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Preforma spins out of control
a couple of thoughts:
1. Take top off and check to make sure springs/absorbers are in place and not broken..
2. Try a load with no clothes and see if it happens.
Good luck.
Feb 27, 2017 | Maytag Washing Machines
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dryer won't turn on
sounds like the bearings on your motor are going bad
Dec 12, 2008 | Maytag Performa PAV2200
Maytag > Performa > Drains,Rotates, Fills but wont spin
I had the same problem with you a couple days ago. I disassambled the whole machine and i found out that the belt worn out and the motor also losen so i am looking for parts to replace.
Sep 05, 2008 | Maytag Performa PAV2200
Washing Machine making an electrical humming sound.
Sounds like a defective part! No way for you to know or fix it your self.
You will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Maytag Performa PAV2200
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Very loud squealing noise in spinn.
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Oct 18, 2007 | Maytag Performa PAV2200
Maytag PDB3600A Built-in Dishwasher Logo
586 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
