Question about Abit IN9 32X-MAX (IN9 32X-MAX WI-FI) Motherboard
My pc works only when I reset CMOS
Abit IN9 32X-MAX Motherboard Problem: My pc works only when I reset CMOS. After a restarting the pc does not work. How do I solve this problem?
  • igeorgop Aug 28, 2007
    I updated the M622A_12.BIN by flashing.
    I also replaced a new battery CR2032.
    Unfortunately I still have problem.
    When I restart the pc it causes an alarm and the pc does not work.
    I always see on the monitor the message "CMOS checksum error-Defaults loaded".
    I don't know how to try underclocking my processor or to try increasing my latency.
    Thanks.
    Brigadier General:
  • 6,966 Answers
Hi, Some of your BIOS settings are not 100% acceptable/compatible with your current setup. I would suggest that you set everything to default, save and close/restart. Another thing you can check is if the Lithium battery needs replacement. Normally it should read 3.0Volts. If the above does not solve your problem, you can consider other things: 1. BIOS update by flashing; 2. Processor to motherboard compatibility - try underclocking your processor by lowering its FSB; and/or 3. Memory to motherboard compatibility - try increasing your latency Good luck and hope this be of some help/idea to you. Post back how things went or should you need further information. kind regards.
Posted on Aug 25, 2007
  • Louie  Role
    Louie Role Aug 25, 2007
    Hi again,
    Was just wondering; if the motherboard is fairly new, it should be still be covered by the warranty. maybe your best bet is to have it replaced.
  • Louie  Role
    Louie Role Aug 29, 2007
    Based on your last comment, I will assume that the mb is no longer under warranty or for some reason you prefer not to claim warranty and that rather than replace, you also prefer to repair and make do.
    Your post/description "...message "CMOS checksum error-Defaults loaded..." indicates BIOS issues which may be:
    1. firmware - but you recently flashed;
    2. CR2032 battery - but you replaced with new;
    3. hardware - component failure in the mb at the BIOS EPROM section, possibly a diode that is in series with the +3VDC supply from the battery. A way to check is to run the PC for a couple of minutes then restart (not shutdown); if the PC reboots without the message "CMOS checksum error...", then it is probably so. You will need a VOM, a low wattage soldering iron and knowledge of forward/reverse bias check of a diode in/out of circuit, desoldering, replacing diode;
    or
    4. Processor to motherboard compatibility - Run at default (disable OC Guru - AutoDrive in the BIOS) run the system at the rated CPU specs or even lower (underclocking) by lowering FSB; or
    5. Memory to motherboard compatibility - try increasing your CAS latency. This is done in the BIOS look CAS latency which probably would be 2 or 2.5, make it a 3
    Cheers
SOURCE:
Siren on boot - removing cmos battery allows startup but any changes to the bios or a restart causes siren to return. Cmos battery replaced - no change. ABIT AX8 motherboard bios version 10
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
don
Feb 28, 2011 | Abit AX8 Motherboard
Whewhere i find the latest errors on my motherboard
Errors in a motherboard is unlikely, you can try resetting the CMOS if you think it has some errors. Resetting CMOS will clear the BIOS settings.
Mar 07, 2010 | Abit A17 Guru Motherboard
My ABIT AW8-Max motherboard is showing an error "83", the manual I got of ine does not explain much other than saying "save all data in stack back to CMOS"! I dont really know what i need to do to fix...
Error message: 83h, Save all data in stack back to CMOS. 84h. Initialize ISA PnP boot devices.
First try clearing the cmos jumper on the motherboard. You will need the manual to help guide you. If you no longer have the Abit manual for the AW8-MAX motherboard you can download it by opening the link provided below; http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AW8-MAX&fMTYPE=LGA775&pPRODINFO=Manual
Click on the blue arrow to start the download.
You will also need WinZip to uncompress the zip file.
Download Winzip @ this link; http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Than you'll need Adobe reader to view the manual. Download and install Adobe @ http://www.adobe.com/products/reader/
Open the manual to page 2-8. Follow the instructions to clear the cmos. (Wait 30 seconds). Reset the cmos jumper back to normal. Boot you're system and press the Delete key on you're keyboard to enter the bios. Turn to page 3-1. Once the bios/cmos has been cleared the cmos resets the bios back to default settings. You will have to change some setting depending what is connected to you're motherboard.
When finished save and exit the bios. The system will auto restart. If you receive the error massage again than you'll need to replace the cmos battery. If after replacing the battery the error message still returns the last option would be to flash the bios/cmos with the latest bios. You'll find the bios file and bios utility/firmware from the Abit link below;
Cheers'
Mike
Mar 02, 2010 | Abit AW8-MAX Motherboard
How do I reset bios on this motherboard? I've tried to find a user manual to download without success.
This link to Abit will get you the manual for the IC7-MAX3 board, which may what you need.
If by resetting BIOS you mean clearing CMOS, just remove the battery.
Feb 14, 2010 | Abit IC7 Motherboard
Bios is not working properly
reset the bios how can you reset the bios open the cover the following instruction and there is a jumper convert into the second jumper then it will be reset
Apr 09, 2009 | Abit BD7-E Motherboard
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
Problem related to System sound
i dont think that is how you reset your cmos did you check your manual? second i had that same problem it it came after i put vista on my pc but it never worked. when i re-installed xp it worked again my guess is to reinstall xp then see if you can find the drivers off the manufactures website. but you say it works for two days then stops i dont know you could try updating the bios (flashing it) good luck
Oct 07, 2007 | ASUS A8V-VM Motherboard
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
Open Questions:
See all Abit IN9 32X-MAX (IN9 32X-MAX WI-FI) Motherboard Questions
Abit IN9 32X-MAX (IN9 32X-MAX WI-FI) Motherboard Logo
146 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
