Question about Akai LCT4216 42 in. LCD Television
Akai 42" LCD has lines on start up
TV is 6mnths old. When I power it on there are lines and or it goes into a scrambled digital mode. If I turn it off and on a few times it goes away. Any suggestions
  • Anonymous Nov 06, 2007
    I have the same problem, lines on start up and completely scrambled video. If I leave it on for about 10 minuets then I recycle power it will sync up enough that I can watch it. It will still have lines across the screen. After it has been on for awhile, the video will drop out again. I have to recycle the power to get video to sync up again.
    Rick
  • Anonymous Feb 24, 2008
    power tv up lines come on to the screen and the picture does not show at all.
I got the same problem on a LCT42Z6TM. It is related to video, occurs on VGA, S-Video and Video Ports.
Posted on Aug 30, 2007
SOURCE:
Tv powers up but goes directly into stand by mode
An Electronic component has failed. Unless you can repair circuits, take it to a shop or friend who can. Consider cost of replacement. A few hundred will fix an old tv, a couple more and you have a whole new unit.
Nov 16, 2013 | LG 42PQ30 42 in. Plasma TV
My Samsung 52 LCD has horizontal lines and scrambles on the the lower right half on the screen
That of course if all boards have been replaced leaves only a defect that is inside the display panel (front screen unit) which is fatal from a cost point of view----unless one of the boards replaced already is bad.
Jun 17, 2012 | Samsung LN52A550 LCD TV
I am currently trying to connect a laptop to my TV monitor for watching Hulu and some wmv files. Everything is fine on the laptop and when i connect via an SVGA cable everything is fine for 10-40 minutes...
Tries go into the computer Control panel go to monitor resolution change it lower resolution like 1020 to 800 should solved ur video problems,scrambling video is tv not supporting the current resolutions.
Jan 30, 2011 | RCA MM36100 36" TV
Hi my garmin nuvi 255w keeps powering off
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 02, 2010 | Garmin nuvi 255W GPS Receiver
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Picture on 15 year old Trintron comes on briefly then goes black
if the sound goes out its not a tube problem . a bad tube would have no effect on the sound .you problem (my guess) is in the power supply . a modern tv power supply has parts of it that stay on all the time unpluging it is not the problem its when you plug it in ! the power supply gets a JOLT . you might get away with it ,you might not . thats why we install surge arrestors on power plugs and with expensive tvs i recomend a UPS a power unit that keeps the tv powered even wnen the line power is out . thats keeps everthing in the sets nice and even ,so the tv lasts longer ... a modern tv turned off uses about 1.40 in electric a YEAR in standby mode , so what are you saveing if you send you set to the landfill early and have to buy a new one ? over 1.40 in electric ? . turn down you water heater or something else simple dont be blowing out you electronics for the sake of a few cents ..... good luck .... if this answer helped please rate a 3 or 4 , this high rateing will hepl keep me in the paid answer department . thank you
Apr 19, 2009 | Sony Televison & Video
Picture keeps getting all scrambled
sounds like a problem with the main board and or av connector cord. contact vizio and let them know you are seeing some red pixelation. some parts on vizios carry lifetime warranties, it has been my experience that this is a covered issue. hope this helps.
Apr 07, 2009 | Vizio 42 in. LCD TV
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Akai LCT4216 42 in. LCD Television Logo
211 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
