Question about Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Stove is suddenly haunted
I was awoken the other night by the range beeping. Since it was 3:30 AM, I was mad someone was cooking! I came into the kitchen and noticed "f-3" on the digital display, and also noticed that the broiler elements in the main oven were glowing bright! I hit clear, cancel, everything I could think to get the elements to turn off! It was almost as thought the oven had autonomously gone into cleaning mode, except that the door was NOT locked and the fan and lower elements were not on! I eventually turned the breaker off! The next evening, I turned the breaker back on, and the same dance started again! Interestingly, when I pressed Bake, Convection, or Clean, the upper elements turned off. When I subsequently pressed clear, the "dance" picked up right where it left off! The broiler elements, when they and the oven were in this haunted mode, NEVER cycled OFF!!!! So the temperature inside the oven was God-knows-what! I have gotten the same "f-3" code once before, when some grease in a broiler pan caught fire, but that was almost a year ago, I had INTENTIONALLY turned the broiler ON, and I was fully awake and aware! I will keep the breaker turned OFF until I can get this resolved, since I don't want my house burning completely down while the oven self-cleans! My range is 5 years old, so there is no warranty, and I have gotten little help from Sears....
  • Geoff807 Aug 25, 2007
    Well, I would have to agree that the oven is too hot! I will look into the main control....
    Thanks!
  • 725 Answers
F3 Oven too hot Replace oven temperature sensor it also sounds like you need a main control too..hope this helps
Posted on Aug 25, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 25, 2007
    sorry I was not clear the f3 code is the oven temperature sensor reading that the over is to hot..
SOURCE:
Getting beeps and f1 error code after canceling cleaning mode a little early.
Hi dear.According to your explanation,Getting beeps & F1 code meaning: F1
Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced.
Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC
I hope that helps.Thanks.
Sep 03, 2010 | Maytag MER5775Q Electric Kitchen Range
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Kitchen Ranges
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
http://www.servicematters.com/maytag_library/docs/16010107.pdf
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven beeping, door locked F9 error
Have you tried to unplug the range for 5 minutes? That may reset the programming that is going on.
Nov 18, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
312 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
