I would like the function keys that enable the wireless connection and may also need directions for how to set the function key because the wifi button is not working.
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
SOURCE: enable wireless card and key number pad
To turn wireless on (or off) press the Fn and F2 keys together.
To enable (or disable) the number keypad, press the Fn and "scroll" keys together.
Here is the online manual for your laptop:
http://support.gateway.com/s/Manuals/Mobile/8511184.pdf
If this solution worked for you, please don't forget to rate me! :) Best of luck.
SOURCE: internal wifi can be enabled but wont find
when was the last time you're connected to the internet using wireless???have you downloaded the latest driver for 802.11???was ur comp able to detect a network???
- if not try to uninstall and reinstall the driver for 802.11
- check the wireless switch then press Fn+F5
- try also to remove ur network if able to detect then manually add it
- if not detecting any networks try to check WLAN Autoconfig @ services.msc at command prompt or run(general tab - start up type should be auto and service status should started
- then first,second and subsequent failure should restart the service under recovery tab
- check ur ipaddress it should 192.168.1.12 something
