Question about GE JBP60 Electric Kitchen Range
"Locked Door" flashes after interrupting self clean
My wife was cleaning the face of the range when she accidentally hit the self clean button. Not knowing what to do, she just reacted and opened the door. Initially, the locking mechanism had moved over into the lock position so we couldn't shut the door. I figured out how to raise the lid and get into the locking mechanism to move it back manually to the "open" position so we can at least shut the door now. However, it still flashes "Locked Door" and we can't do anything with the stove portion of it. I suspect there's a solenoid that still thinks the mechanism is in the locked position that needs to be reset. I've tried running it through the self clean cycle and recycling power on the unit. No change. Suggestions? TIA, Robert
  • robertkbrown Aug 25, 2007
    Thanks Catriver,
    I think I'm doing something wrong. I pull the power cord and hold the cooking time and delay start pads together while my wife plugs the range back in. At this time, the screen says 72 (degrees) and "test". I press "8" and nothing changes, the screen still just says "test. I tried pressing and holding the "self clean" pad, but nothing happens (tried holding it for about 10 or 15 seconds). The whole time this is happening, it's still flashing "Locked Door".
    What am I doing wrong?
    President:
  • 878 Answers
Robert, see if you can get it back home by using the test funtion. Kill the power to the oven. Turn it back on and on the control press and hold the cooking time and delay start pads together. While hold these keys, press the number 8 pad. The words test should appear in the display. Now press and hold the self clean pad and it should cycle the cam through the whole process. Here is what you should see. 1 test (unit is in unlocked position 0 test (moving toward latched pos. 2 test (latched position 0 test (moving toward unlocked pos. 1 test (unit is in unlocked pos. Press cancel to exit the test. See if this gets you going again, let me know, Catriver
Posted on Aug 25, 2007
My kenmore 46745 or 46749 (both models listed on the manual) door is jammed. I accidentally opened the oven door, stopping a cleaning cycle after only 15 seconds, and now the door will not close...the lock...
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Nov 26, 2010 | Kenmore 45781 / 45782 / 45784 / 45789...
"Locked Door" flashes after interrupting self clean...
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control: Motorized Switch 1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel. 2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed. 3. While you hold the door jamb switch in this position, complete the following steps. 4. Press the Clean pad, wait 10 seconds. 5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it. 6. Wait 10 seconds for the display to clear. 7. The door should unlock and there should not be a need for service. Manual Switch 1. Press the Clean pad. 2. Close the door. 3. Slide the latch to lock the door. 4. Hit the cancel button immediately. 5. Unlock the door.
Aug 25, 2007 | GE JBP60 Electric Kitchen Range
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
"Locked Door" flashes after interrupting self clean (follow up)
GE JBP60 Electric Kitchen Range Logo
195 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
