Question about Toshiba MV13P2 13 in. TV/VCR Combo
Toshiba TV MV13P2
BIG black box appears on my TV. Push any button and it goes away for a few seconds.
  • jodi211999 Aug 24, 2007
    I turned off the Closed Caption. It disappeared. However after 5 min utes, it reappeared. Another suggestion?
  • 398 Answers
All I can say is that the black box appears when the closed captions are on and set to TEXT. This is normal. Turning off the closed captions should make the black box go away. If the closed captions are somehow turning themselves back on, there may be an issue with the microprocessor in your TV.
Posted on Aug 25, 2007
SOURCE:
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Black box appears on tv screen then disappears. sometimes the box has letters in it. it last for a few seconds then it goes away
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Mar 21, 2010 | Sharp LC-19SB14U 19 in. LCD TV
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
Jul 09, 2008 | Toshiba 57H82 57" Rear Projection...
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
Toshiba MV13P2 13 in. TV/VCR Combo Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
