Question about NetGear WGT624 Wireless Router
My laptop and the router won't stay connected.
During use, my laptop will seemingly randomly lose connection with my router.
  • spham2147 Aug 24, 2007
    What is "netgear PCMCIA"?
    Problem Solver:
  • 12 Answers
This is common with many manf. of routers. I have had the same issue. Are you running WEP? If so that's probably the culprit. For some reason, IEEE allowed more than one hash routine to get out there in the field, so sometimes if you have varying brands end-to-end, they can generate the hash-to-value a slight bit differently. So either a)Disable WEP b)Get netgear PCMCIA on laptop c)Move closer or change string in your WEP key to ONLY include 0-9 a-z d)Get a repeater. (Either netgear or brand of laptop WLAN NIC) Hope this helps. (I ended up disabling WEP as MAC filter and SSID turned off are sufficient enough for home use security.)
Posted on Aug 24, 2007
SOURCE:
My acer aspire loses its signal randomly then comes back. Other laptops in the house are fine for connection. Any advice in simple terms appreciated as I don't know how to remove acer software for
Have had similar problems with two Gateways that are actually Acer--both two feet away on either side of each other: one or the other will lose connection--so not the units---if move the one not connecting closer (it is 50 feet with 3 walls between it and router) it will then pick up the wireless and work fine--I answer about 300 questions here each week so end up to avoid this in the mud/laundry room where I can depend on the signal and also have a smoke if I want.
May want to as a test move it closer to the router and see if same issue or not.
Apr 20, 2012 | Acer Aspire One AOA110-1588 Notebook
Hello, My roommate and I play World of Warcraft...
I would reset the router to default settings and use the good version of the firmware. OR delete your existing internet setup and then re-add it (do this if you didnt factory default your router before upgrading firmware)
May 20, 2010 | Computers & Internet
Lose connection to internet at random times
There could be several things that can cause this problem, ranging from low signal strength, electrical interference, clashes with other wireless routers in your area etc.
Please click on this link and follow my instructions for possible solutions to your problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
May 12, 2010 | 2wire (2701HG-B) Wireless Router
Randomly lose internet connection, possibly the
It is your ISP - check with them - - they did it to me unil I threatened to leave if it continued.
May 11, 2010 | 2wire 2700HG-B Router (2700HGB)
Continually disconnects internet at random
You have WR160N router. This router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Apr 27, 2010 | Linksys WRT160N Wireless Router
Wbr-2310 wireless stops resonding randomly.
unplug for 10 seconds, plug back in. These units to tend to get a stat build up charge
Nov 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
HP dv6139 loses Inet connection after 5 minutes (both ethernet & router)
Most probably it's the router's fault, if you have one. I've seen many cheap routers randomly loosing wireless connection with their computer clients. Try with another router. One possible solution: upgrade the router's firmware.
Oct 23, 2008 | Computers & Internet
Router rebooting?
Try the following...
  1. Is your Power adaptor is loosely connected to the power socket?
  2. Check is the power adaptor produces more heat?
  3. Try to connect the device to the UPS if not..
If these are not the issue then there is possiblity of device failure.
Jan 27, 2008 | D-Link AirPlus DI-524 Wireless Router
NetGear WGT624 Wireless Router Logo
122 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
