Question about Motorola Mobility RAZR V3
Fone freezing my fone won't turn off properly. its frozen on a screen telling me i got messages but won't let me read or exit.Won't do anything
Sorry to be a pain...but how do i reflash the firmware????
Posted on Feb 24, 2008
    Brigadier General:
  • 7,752 Answers
Reflash the firmware on the phone this will correct the issue
SOURCE:
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
Freezer won't freeze and fridge side freezing vegetables
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Dec 08, 2017 | Samsung RS2630WW Side by Side Refrigerator
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
SAMSUNG FINESSE SCREEN IS FROZEN AND WON'T WORK
Have you tried taking the battery out and then re-inserting it and turning it on again? Freezing is a common Samsung problem, and my phone tech suggested this remedy -- it's worked every time.
Jul 22, 2011 | Samsung Instinct Cell Phone
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
I have a nokia 5300 and all of a sudden when i turn on the phone the screen freezes and shuts off and turns back on but i can't get to my messages or anything that is saved on the phone. If i talk on the...
Hi there.. I believe that you are one of those very active and busy type people who are always on the move. The general reason I believe that you fone is behaving this way is because you do not allow your fone to charge properly, therefore limiting the lifespan of the battery.
My advice: -try and drain you battery dead until you are unable to turn it on at all.
- secondly,charge your fone till it says fully charged.
-thirdly, when using your fone you can either 1). repeat the previous steps and this time drain it by playin music or 2). try using it with caution..
-lastly, next time you decide to charge your fone make sure it is dead/off till you charge it.It should last you a good 2days if all goes well.
These steps can help you prolong the life of your battery and save you $50 to buy a new one..
May 05, 2009 | Nokia 5300 Grey Cellular Phone
How to unlock privacy code t-mobil sidekick slide
all u have to do is while the fone is on take the battery and sim card and or sd memory card out. then put only the battery in and turn the fone back on while holdin down the r botton the fone will then reboot it-self twice then let the r botton go and allow the fone to turn it-self on. the fone will then turn on to the main menu screen and u will not be able to do anything wif the fone till u re-register the fone.
Mar 14, 2008 | Cell Phones
Freezing
there must be water entered in the set ... get it serviced if not solved ... change the dailing stripe.
Aug 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
97 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
