Question about GE JBP65 Electric Kitchen Range
GE modelJBP65G V2AD hitchen range
The last time my wife used the oven she had it on 350 degrees in bake mode. After it preheated the preheat light and beeper went off. After she had cooked the roast she had in she turned all the knobs to off and the bottom/bake element in the oven stayed on. The only way I could get it to go off was to pull the breaker. I would like to know if it is the timer, element, or what. I dont mind trying to fix it buy I hate to guess at it. Any help would be appreciated
  • bigfig Aug 25, 2007
    Thanks for the info. The TO8 control is the oven contol and clock together? If I want to replace it....how much? Trying to keep the cost down due to the age vs buying another unit.
  • bigfig Aug 26, 2007
    thanks for the info. as soon as I get a minute I will take it apart,,,thanks again
  • 725 Answers
It sounds like your TO8 CONTROL it is you oven controls and clock. let me know if you want to replace it ..
Posted on Aug 25, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    Yes both the conrtol and clock are together..
    JBP65GV2AD WB27X5562 CONTROL TO8 retail for $291.56 check around you may find it cheaper..
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
My Jenn Air JGS8850 takes over 10 minutes to preheat to, say, 400*. Is this normal?
In a word...Yes !
10 min. is actually a really great preheat time. I have many customers who would kill for that kind of preheat, most are between 15-20 minutes minimum to 350 degrees celcius, especially with the introduction of hidden bake elements in the last 10-15 years.
Hope that is helpful,
Good Luck :)
Oct 22, 2009 | Jenn-Air JGS8850 Gas Kitchen Range
My GE Profile Spectra oven is taking approximately 10-15 minutes to preheat to 350 degrees and does not seem to fully bake food as per instructions. It takes an extra 5 to 20 minutes to bake anything. ...
18 mins from room temp to 350 is factory standard,
you may need to calibrate the range, most now adays come factory set at -25 degrees for safety
depending on your model number in your instruction manuel should be a part about recalibrating it sounds like your about 25 degrees off
Oct 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Items are not baked all the way through
Put a thermometer in the oven to see how the temp is vs what you set it at. If temp is off by more than 25 degrees replace the oven sensor. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | GE Spectra JBP78 Electric Kitchen Range
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
GE JBP65 Electric Kitchen Range Logo
410 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
