Question about Maytag Neptune MAH9700 Front Load Washer
Hr error code
It just stops with hr flashing
  • Anonymous Jul 24, 2008
    Just wanted to say thank you....perfect solution for a piece of .....washer!
    Keep up the great support.
    President:
  • 1,294 Answers
Press "end of cycle" to get machine to normal. Then plug off the wall. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 07, 2008
SOURCE:
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
What is error code Hr in the 2007 subaru legacy?
There isn't actually an "Hr" code, but there is this code for the high speed CAN network communication failure. If you've had your car worked on recently I would take it back to whoever worked on it last and have them check it out. Usually caused when someone doesn't tighten a ground wire back up for some reason. Here is a Subaru TSB that covers some of this. http://ww2.justanswer.com/uploads/n9320h/2010-07-16_222648_sub.pdf
Er HC High speed CAN communication failure
Aug 28, 2014 | 2007 Subaru Legacy 2.5i SE Sedan
Why does the engine light start flashing when i brak
stop immediately, call AAA for a tow to your mechanic.
Generally a flashing "Check Engine" light requires immediate attention to avoid possibly very expensive engine damage.
If you have a friend like me locally who has a OBD Engine analyzer, you get the error codes, translate the code for free and fix it yourself if you have the skills. I got my Innova Brand at WalMart for $120 in Hawaii. Mechanics will charge $100 to hook up the analyzer, plus $60/hr minimum service fee.
Nov 17, 2012 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
Maytag Neptune MAH9700 Front Load Washer Logo
602 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
