Question about Nikon N65 35mm SLR Camera
N65 Error The display flashes err and a backward 3.
  • 2 more comments
  • tulip04 Jun 12, 2008
    Mine also displays the Err and E (empty). I have advanced the film past the red mark and it is still giving me the same error. I have tried advancing the film more but it is not helping. I have tried using other films- same error. I just changed the battery.
  • biddies Jun 26, 2008
    The note error comes up.
    The note says E when the film is fully advanced.
  • Anonymous Aug 05, 2008
    my camera say err and wont connect to the film
  • perez_jmanue Dec 18, 2008
    I have not used it for a while, so I insert batteries and load film. I see E error, I take out and reinstall batteries, reload film, same E error. I even take some test pics, same error. Film looks OK, how can I make sure it is properly loaded?
    President:
  • 1,114 Answers
I believe the N65 is the same as the F65 which you can download a manual on on this link: http://nikonasia-en.custhelp.com/cgi-bin/nikonasia_en.cfg/php/enduser/std_adp.php?p_faqid=3132&p_created=1102164682&p_sid=DlYIXTJi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NiZwX3Byb2RzPTAmcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWY2NQ It seems the film is not loaded correctly. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 24, 2007
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
Flashing err on nikon n50
Hi Jennifer,
Not too sure what that is, but first thing I would check is that you lens is set to its smallest aperture, such as f/22. Many times that err message means the lens is not closed down all the way. After closing the lens down the camera dials will set the aperture. Also, on many Nikon D type lens, not the G type, there is a small push pull button to lock the lens as it smallest opening.
Cordially,
Mar 06, 2013 | Nikon N65 35mm SLR Camera
I bought new batteries for my N65 and my camera keeps blinking ERR.
The manual mentions only 2 conditions where the Err message appears. First if it is Err + E at the same time, the film has not completely wound and needs to be reloaded.
If it is Err alone, the manual states to fire the shutter and see if the message remains. If it does, to contact a Nikon Authorized Service Rep.
Jun 23, 2011 | Nikon N65 35mm SLR Camera
BOSCH WAA24270GB error code 0 and 2 backwards rr
Press START button over 10 second, its working for me
Apr 09, 2010 | Bosch Washing Machines
I have a Nikon N65 and I just replaced the batteries. When I turn the camera on, I can't change the shutter speed/aperture or anything (on any setting..manual, auto, etc) and Err flashes.
Camera has a fatal error and should be sent in for service, or replaced. A used on may actually cost less than repairing your old one. Check out KEH.com
Nov 09, 2009 | Nikon N65 35mm SLR Camera
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Flash
You might not have your lens set to the minimum aperture setting (the largest number) if it is a non-G lens.
Nov 29, 2008 | Nikon N65 35mm SLR Camera
Err 99(Error Code). Removed battery and re-instaled. Still no image on display or Flash Card. Problem with my EOS Rebal 300 Digital Camera.
Seems to be related to the lens, is it fit to be used with this camera? disconnect the lens and try again.
Aug 19, 2008 | Cameras
ERROR CODE E63:20
sir E63 ERR is related to lens err ur camera lens unit dislocated or gears problum. this is easyly repairable
Dec 31, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Nikon N65 35mm SLR Camera Logo
384 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
