Question about Whirlpool RF368 Electric Kitchen Range
Door the door does not close tight,sometimes the light comes on, and you must push the door shut.
  • mdm428 Aug 24, 2007
    This is second Range of this model,in less than a year in service,that I know of with this problem.
  • 63 Answers
Sounds like door hinges are bad weak springs
Posted on Aug 29, 2007
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Door ajar light keeps coming on but doors are shut tight/2000 dodge caravan
with car in park and emergency brake applied, engine running, all doors closed on flat, level surface: sit behind the wheel, watching illuminated door-ajar light -- have a friend push one each door (right at the door-jam edge) hard enough to rock the vehicle, but not hard enough to dent the doors. if the light filckers off, that door is where your problem is...--> check the functionality of the switch/button in the door jam that plunges in when the door is closed. It may need to be replaced or may just need a spacer added between the switch plunger tip & the part of the door that pushes it in.
Aug 09, 2012 | 2000 Dodge Caravan
My car keep showing "door ajar" all the doors be
One of the doors is probably not shutting tight enough. When the light is on and all doors are closed, have someone walk around the car and push in on each door. When the light goes out, that is the door that needs adjusting. Adjust the lock so that the door closes tighter. Let me know if you have questions.
Nov 05, 2010 | 2004 Chevrolet Impala
Door ajar light is on but all doors are closed? Havent checked anything aside from shutting all the doors. Its a 2003 vw jetta gl 2.0l 4cyl. Not sure why the door open light in the driver panel stays on
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the door open light coming on It could mean one of the the door catches is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in, especially the driver's which gets the most use and see if the light goes out. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact.
Oct 26, 2010 | 2003 Volkswagen Jetta TDI
Light sometimes flash on and off on the dash board. the diagram indicates that the right rare door is open but it is closed. When door is opened and closed the light comes off but it soon returns.
there is a switch that the door triggers when it is shut,located somewhere around the framing of the door,start your car wait for the light and push the switch in by hand to see if the light goes out,if not wiggle it while pushing in to see if it works.It could be loose or bad altogether
Oct 07, 2010 | Honda Accord Cars & Trucks
While i am driving, my dome light will flicker on and off. But sometimes it just stays on the hole time im driving until I shut the vehicle off. What is the issue or problem? I was told it could just be...
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the Dome light coming on. It could mean the door catch is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in, especially the driver's which gets the most use. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact.
Don't forget to rate this post !
Sep 30, 2010 | 1998 GMC Jimmy
CRFATSMAN opener - Problem when closing only
It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Three beeps
Replace the bulb and door switch.. (cheap)
last would be this 3-beep problem..
http://www.youtube.com/watch?v=tq3k22cqjR8
Mar 27, 2008 | Kenmore Elite HE4 Electric Dryer
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool RF368 Electric Kitchen Range Logo
57 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
