I have a RCR universal remote. It turn the tv on/off but the red lock remains on my apex 2011s. What do I do?
    Top Expert:
  • Televison & ... Master
  • 76,060 Answers
The Apex prompts you to
enter a 4-digit code when you set up parental controls. You can block programs
according to their MPAA ratings or their content designations, such as V for
violence or S for sexual situations. You can override parental
controls on most Apex models by simultaneously pressing the F and mute buttons
on the remote control. If you own Apex models GT2011J or GT2011S, hold the
remote\'s display button for ten seconds. The red key will vanish and the V-chip
will unblock your program.
Apex\'s default parental
lock control code is 6688, so if you haven\'t set a new code, entering 6688 will
remove the red key and unblock your program. If you\'ve set a new password and
forgotten it, entering 3308 will reset the code and unblock your program. For more, http://electronicshelponline.blogspot.com/
Posted on Jul 02, 2013
SOURCE:
AvioriX
  • 689 Answers
SOURCE: I need remote code for a RC24912-D
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
Posted on Jan 09, 2008
SOURCE: NEED CODE FOR APEX TV
try buying an apex remote control
Posted on Aug 31, 2008
SOURCE: RCR universal remote model# rcr461
I programmed my RCR461 to an Emerson TV by entering code 1170. On the DirecTV, I entered 5059. Found them the hard way, but it works....
Posted on Dec 04, 2008
  • 60 Answers
SOURCE: RCA rcr 461 remote won't program
Search for the codes in here. It's RCA's remote code finder.
Posted on Aug 24, 2009
tthekraut
  • 374 Answers
SOURCE: need apex tv code
the standard codes for apex are: 0023, 0223, 0123, 1814, 0741 .try each one of these until you find what works with your tv.
comment if you need any further help or if these do not work.
Posted on Mar 17, 2010
Trying to remove parental lock on Apex Digital AT 2702s 27'' tv with a RCA universal remote
The parental lock is part of the initial setup procedure selected by the Apex remote.
Mar 05, 2013 | Apex Digital AT2702 27" TV
Codes for apex tv
Hello
Setup codes for Apex tV with "Comcast Ondemand Custome-3 Universal" remote control are:
0748, 0765, 0767
Setup codes with RCA RCR 3273N universal remote control are:
10156, 10748, 10879, 10765
OK.
Jul 31, 2011 | Televison & Video
I have an apex ld3249 tv with remote. The remote died a couple of days ago. I have had the tv for 6 weeks. A universal remote will not work. A new Apex remote is $60. Is this going to be an ongoing problem...
Hello
There is no warrantee for the remote control for any company's set. A universal remote should work with your Apex tv. I'll give you the model and codes for the remote that suit to your apex TV. Buy one and match it to your TV.
PHILIPS [CL 034] universal remote control.
Codes are:-
0023 0223 0123 0741
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 15, 2011 | Apex Digital Televison & Video
How do i program a universal remote control to my Apex TV
Hello
Universal remote code for Apex are:-
o516 0214 0216 0215 0401
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Jan 08, 2011 | Apex Digital PF2025 20" TV
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
I bought a rca universal remote, how do i program it to my apex tv?
Try the below i hope it helps I don't have the codes, however I can tell you how to find the code on your remote without pressing any numbers! Hold the code search button until the red light on the remote remains on. Then, press "TV". After this, point the remote at your television and press the power or on/off button over and over again SLOWLY (one time every second) until the TV turns off. DO NOT PRESS THE POWER BUTTON AFTER THE TV TURNS OFF!!! Once it does, press the "enter" button on the remote. Then, the remote should work on the TV. 100% 1 Vote
Nov 30, 2009 | RCA Universal Remote Control
My remote number is RCR 312w
Hi!
The codes for Apex TV are--- 1236, 1243, 1244
Please visit this link for more details---
RCA RCR Remote Codes
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 26, 2009 | RCA RCR311B Remote Control
Code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
May 02, 2008 | Directed 434MHZ Remote Control
RCA RCR 3273 universal remote
for codes:
http://www.rca.com/codefinder
Nov 27, 2007 | RCA Universal Remote 3 Device Remote...
My TV is completly locked up
You need a APEX remote to unlock the parental controls. You and go to there web site to get the ording info and he preocedure to unlock the tv. www.apexdigitalinc.com
Apr 19, 2007 | Apex Digital AT2708 27" TV
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
