Question about Canon BJC 4300 InkJet Printer
Just replaced the BLACK cartridge and the printing has blank lines on it. Tried turning it off, disconnecting, cleaning, but it does the same. I can't find my installation dvd. Can you help me? Thanks
    Master:
    Sergeant:
  • 461 Answers
I assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Posted on Aug 30, 2007
6ya staff
SOURCE:
Green light is flashing on printer - cartridge won't slide back and forth so 4300 printer will not print
If cartridge is in the middle and won't reset to the right, it is likely a bad printhead (BC-21e).
Jan 18, 2010 | Canon BJC 4300 InkJet Printer
After installing new black cartridge into printer will not print!
dear friend
this error due to filled waste tank You must replace waste ink tank.Visit u r nearest canon service location or dealer point
Jul 02, 2009 | Canon BJC 7100 InkJet Printer
Canon BJC 80 prints blank pages!!
Power off the printer.
Unplug it, then plug it back in.
Wait until it stops its initialization sequence.
Press and hold the power button.
Allow the printer to beep 7 times, then release the power button.
This will reset the EEProm to factory default, and should clear your problem.
May 26, 2009 | Canon BJC 80 InkJet Printer
Can I use only a black BJ cartridge on a Canon 620 printer?
Nope. You can use Cyan, Magenta and Yellow as well as Black.
Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at PrintCountry.com
    Canon.com's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    Canon bjc-4300 cartridge insists on staying in middleofprintfield
    Normal 0 Driver could be corrupt.
    Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 06, 2009 | Canon BJC 4300 InkJet Printer
    Printer won't print
    It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
    Sep 07, 2008 | Canon BJC 4300 InkJet Printer
    Canon bjc-80 - no print appears but cartridge & paper move normally
    I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
    Nov 12, 2006 | Canon BJC 80 InkJet Printer
    Open Questions:
    See all Canon BJC 4300 InkJet Printer Questions
    Canon BJC 4300 InkJet Printer Logo
    1,222 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
