Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Clean machine All the belts are fine but the machine does not pick up the water. I think it is clogged with pet hair but don't know where to clean it out. I have taken off the roller, etc. but nothing seems to work.
This is what was wrong with mine....very simple solution to fix: Check the bottom of the water reservoir. It should have a black rubber washer attached to the lip that goes down into the main system. If that part is inside the main system, instead of attached to the water reservoir, the reservoir doesn't make a tight enough seal for the suction. Just carefully remove (I use tweezers) the black rubber part (almost like a thick washer) and put it on the reservoir. Should fix the problem!
Posted on Sep 07, 2007
SOURCE:
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
Why is the pet hair power brush not spinning?
Amazon.com: Customer Discussions: Shark pet hair & power brush
www.amazon.com/...pet-hair-power-brush/.../1?_...
Amazon.com, Inc.Jun 24, 2012 - I needed the belt and couldn't find one so I used a black heavy ponytail band in its place and it works, I don't know how long it will last, but until I ...
My shark pet hair power brush tool will not spin - Fixya
www.fixya.com/.../t13829250-shark_pet_hair_power_brush_tool_will_n...
Jul 30, 2012 - Posted on Jul 05, 2015.
Sep 21, 2015 | Shark Rocket Professional Self-Propelled...
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
My pet vac only pick up via the tools and the brushes are not spinning
1( test the belt , can be worn, and replace
2( test the power brush and clean, and replace if necessary
3( clearing the hose.
4( see the diagram.
5( test the motor if need Repair.
Sep 06, 2012 | Bissell Upright Vacuum - The Pet Hair...
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Dec 30, 2009 | Bissell Upright Vacuum - The Pet Hair...
I have a Lift Off Pet Bagless upright and ever since I **** up a hair tie it hasn't been **** up the dog hair from my carpet. I have gotten the hair tie out of the vacuum but it is still not **** up.
One of the reasons it might not be picking up is because you have a worn belt. The other reason could be that the suction channel is clogged. Did you remove the hair tie you ****up? If you need a replacement belt you can get it here: Bissell Lift-Off Pet Replacement Belt
Oct 30, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
76 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
