Question about Mitsubishi WD-52725 52". Rear Projection HDTV
TV shuts off automatically
The image on the TV screen freezes, or the screen turns solid blue, or dispays distorted images for approximately 30 seconds then shuts down. The timer light blinks until the reset button is pressed. Sometimes the reset button needs to be pressed several times to clear. The timer light starts to blink automatically even when the TV is turned off. Sometimes the TV will work for several hours. Other times it will shut down automatically after only a few minutes. An authorized service center has replaced the signal board, three differenct DM boards, and just recently the formating board. Is this TV irreparable and unsatisfactory?
  • 1 more comment
  • ttay Nov 06, 2007
    We're having the exact same problem. TV could stay on for weeks then the screen turns blue, then it eventaully turns off. Sometimes the green light will flash and go off after 30 seconds or so or it could remain flashing for minutes. The first time this happened tonight, the TV stayed on for 2 hours the next 3 times it happend, the TV only stayed on for a couple of minutes.
  • birdine Nov 29, 2007
    wd-57734 mitsubihi 57 in.screen turns blue,no picture but have sound.then it shuts off.its brand new
  • jlwxford Nov 02, 2008
    The screen goes blue, then they TV turns off. Once off, the green light flashes for about a minute then stops. I can then turn the TV on and it is back to normal. It does this at irregular intervals. I have a power conditionner/surge protector on it.
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Posted on Oct 31, 2007
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
Phaser 560 error 73
Follow these steps :
Do power cycle
Turn the printer off, wait approximately 30 seconds and then turn the power back on.
Reseat the Imaging Unit
Unscrew the two blue screws on the Imaging Unit (one in the upper-right corner and one in the lower-left corner) and then turn the blue, bottom lever counter-clockwise 180 degrees.
Slide the Imaging Unit out of the printer half way, then firmly reseat it.
Tighten all three blue knobs so that the arrows all line up.
Check this and see if it help you else the Imaging unit will need a replacement.
Check this link for detailed steps
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=371,E=0000000002358180192,K=6211,Sxi=1,Case=obj(12762)
Oct 29, 2010 | Xerox Phaser 560 Laser Printer
Usually when I turn on this TV, I get a severely distorted image. I get a black shadow that is approximately horizontally centered and reaches the vertical extremes. The shadow is wavy and distorts the...
The problem is mainly from the lamp of the television, it is about to develop some fault, so i will advice you have it checked and replaced. Before it gets worse.
Good luck and take care.
Oct 15, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Rca 52" projection image problem
Try this with TV off Press and Hold at same time ch- and vol - until TV comes on It should either let you into service mode or start convergence Automatically
Sep 25, 2009 | RCA P52929 52" Rear Projection Television
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Blue screen!
open... and clean the ui teminal of the lcd
Jun 29, 2009 | Nokia 6080 Cellular Phone
Samsung 19" LCD TV Freezes Image and Restarts Itself
I agree with Samsung. Tuner issues can be problematic. Since it's only a 19 incher, I'd just buy a new one!
Apr 11, 2017 | Samsung LN-T4665F 46 in. LCD Television
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
492 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
