Question about Hoover F5906-900 Upright Steam Vacuum
Water tank doesn't dispense water
Water tank (top part, not the dirty water tank) doesn't dispense water at all. it worked fine a few days ago but not it doesn't. what does seem to be the matter and what should I do to fix it?
  • jihee Aug 27, 2007
    water is not coming out. sucking is just fine.
  • Anonymous Mar 31, 2014
    first day using, first room excellent
Water is not coming out or sucking up water
Posted on Aug 27, 2007
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    My hoover steam vac is dispensing water just fine, but is not picking up any water, i have secured the return compartment lid and made sure that the filter isnt too high, still not working
    Another reason for no pick up is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
    Jun 14, 2011 | Hoover SteamVac F5914-900 SpinScrub...
    Need directions to fill , and how to use
    Hi
    I have one just like it. Lay the machine back by pressing the pedal on the left side of the machine with your foot. Now you can get to the handle for the clean/dirty water tank. Lift this off. There's a clip in the back to separate the top sweep section from the tank. Take off the top. You'll see an open hole on the top for filling the bladder inside. This is for clean, hot water only. Fill the bladder, around the bladder is where the dirty water goes back in. you can drain the dirty water by pouring out the corner. There is also a plug on the bottom for draining the bladder when you're done.
    When you put the sweep section back on the tank be sure to catch the front part over the edge of the tank or it won't stay on. Then fasten the clasp and put it back in place.
    To fill the soap dispenser... find it at the back of the machine at the bottom. It just lifts out of the machine. Fill to line and reinsert.
    Hope this helps.
    Handy Andie
    Mar 20, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
    Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
    the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
    Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Kirby Shampoo system not dispensing foam
    Few possible causes
    1. Valve under the sponge (water tank) is clogged. Replacement HERE.
    2. Tray is now lowered all the way down.
    3. You use non-foamy solution.
    4. Carpet is very dirty so foam gets broken up very fast
    Hope this helps,
    Rocky
    Sep 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
    Hoover 3010 FloorMate Plus not dispensing liquid
    With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
    Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
    Will not dispense water or solution
    On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
    Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
    Won't dispense solution
    Check the filter inside the dirty water tank. If it is pushed all of the way to the top, then it won't spray or suck. Also if this has the type of hose that has a block attached to it, when you removed the hose, did you put the other block back in place. Check the seal that the solution tank sits on.
    Jan 09, 2008 | Hoover F7431-900 SteamVac Vacuum
    Not dispensing soap; won't pick up moisture.
    Check the filter on the bottom of the lid for the dirty water tank, make sure it isn't pushed all of the way up, needs at least a gap of 1/4 inch or so. Also make sure that the lid for the tank is locked down and not loose on one end.
    Sep 10, 2007 | Hoover F5906-900 Upright Steam Vacuum
    Hoover F5906-900 Upright Steam Vacuum Logo
    491 people viewed this question
    Top Hoover Vacuums Experts
    Jim Parker
    Jim Parker
    Kirk Thompson
    Level 1 Expert
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
