Question about GE 31GT660 TV
Video input I do not have the remote or manual that came with the TV. How do I switch the TV to a mode or channel for using my DVD player or video game system? I have tried channeling down to find an A/V In channel and using the built in setup feature.
  • 1 more comment
  • tuffghost Aug 29, 2007
    I got a remote for less than $9. Thanks.
  • screwball52 Jan 20, 2008
    i have a Hughes direct tv remote i prgramed in the code for my model# 46GW948 projection tv every thing works except the input button so my dvd player will not show on tv screen
  • oirotnom May 07, 2008
    the jack that you would scew the cable to on the back of the TV is broken.So..i was hoping to run it (cable) with the red white and yellow RCA plugs from the back of the cable box to the inputs on the back of the TV.I tried this ...but you must have to put the TV in another mode besides channle 3.............can someone help
  • 30 Answers
If there is no input button on the tv itself to change the input then you will most likly need a remote. so you can get a universal remote and follow the instructions to adapt it to your set then you can use it to change the input. (you can get a universasl remote for like 10$) hope it helped
Posted on Aug 24, 2007
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
I have an old sylvania 6419 ctc 19 inch TV. I have a DVD player input in to the RCA inputs in the front of the TV but I do not have the remote. Is there any way to switch the TV to Video mode from the...
Tries tv manual channels buttons up or down few times some analog tv will let go into the video mode.Not,try website like Remotes.com to buy the tv original remote.
Jun 13, 2011 | Sylvania 6419TE 19" TV
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Samsung 15" ltn1535
Hey mcca,
In many cases, blue screens on TV's can be the result of the TV being in the wrong video mode or another device (like an attached VCR) being on the wrong station.
First, I would suggest testing to make sure that your TV is in the correct video mode and station. Depending on how many devices are directly connected you to your TV, you may need to cycle through one or two video mode settings using your remote control before the DVD menu can be displayed. Typically this can be done by pressing the "Menu" or "Input" button on most remote controls, but you may wish to refer to your owner's manual for instructions how to do so with your specific model TV. In some cases, the primary video input station is even set to channel 3 or 4 by default.
If you are sure that the TV is on the right input setting (and your DVD player is connected to a VCR), I would next suggest making sure that your VCR is on the right channel. Many VCR's will also require that the channel be set on 3 or 4 in order to display any images being sent through them by a secondary device, like a DVD player or video game console. Additionally, it may even be necessary to change the input setting from "TV" to "VCR" to display signals from an attached device. Again, you would need to refer to your owner's manual documentation for specific instructions.
Lastly, if you use an RF modulator or video signal switch for any devices in your home theater, you may want to make sure that they are on the correct settings.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 28, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Aug 13, 2007 | Sylvania 6427TE 27" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
GE 31GT660 TV Logo
392 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
