FixYa.com
Tags:
Tag Heuer Wrist Watch
Tag Heuer Aquaracer calendar problems (by 3 users)
posted by cipperob on Aug 24, 2007
The date on my watch changes every 12 hours or so instead of 24. What is going on? TIA
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Feb 11, 2008
I can't set the date either....can't pull out the knob to do it???
Comment by debachniecee, posted on Jan 27, 2008
Same problem yet, I cannot seem to pull out the dial on my ladies aquaracer 300 meters.
Best Solution
posted on Mar 17, 2008
FixYa! (100)
Nigelino
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 25, 2007
FixYa! (100)
don1421
Rank:Wiz Wiz
Rating: 84%, 97 votes
To test this. Pull the crown out as if to set the time. Now run the hands around clockwise for a full day. check to see when the hands cause the date to change,that is midnight continue around until you get to the correct time. Push in the crown one click and set the date. This should solve the problem.
Donald
Rating Locked! (?) cipperob has rated this solution as FixYa!
Solution #3
posted on May 22, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
2+2
Can you Help with these Watches problems?
Watches
I got the hair coloring
I got the hair coloring device... Answer This...
Tag Heuer (cj1110.ba0576) Wrist Watch
need instructions for resizing...
I took my watch to Tourneau and... Answer This...
Tag Heuer 6000 Strap Broken
My strap is broken at one of... Answer This...
tag link automatic chronograph
Hello, I just got a tag link... Answer This...
Cross ladies chronograph Tag...
The minute indicator on my... Answer This...
Repair Service
Find Watch Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
