Fujitsu Siemens AMILO D-7830  PC Notebook
Problem for Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook
Toshiba m105 s3004 bios password
By lrlambe on Aug 24, 2007
I have a toshba notebook and had a problem with the HDD password and i got told to just pull out the bios battery and let it set for bout 5 min, well done that and now its telling me to put in the bios password. is there a way to reset the bios password? Thanks
Comments:
Aug 24, 2007
- What will I have to do after I find the cmos clearing terminals on the motherboard called clrcmos or clrclk or jbat1?
Same Problem
Dec 08, 2007
-   the toshiba brand is toshiba satellite A135 s2386, it was forced to shutdown. when restarted again it requested for bios(system) password even before booting. have tried to open the sytem to find a battery jumper . i found the battrery but it can not be removed.
i have tried to short some jumpers too but its just a guess work. pls help.-   indigodammy
Best Solution
posted on Aug 24, 2007
Very Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5937 votes
sometimes it is not possible to clear the bios password on a notebook as the manufacturer guards against it in some cases, but you will probably have to remove the cmos battery and also look for the cmos clearing terminals on the motherboard called clrcmos or clrclk or jbat1 or similair also, to try to delete any password.
Comments:
Aug 25, 2007
- the password should be deleted after you have done that, if not go for jmorgan123's solution
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 01, 2008
Very Helpful)
eloso
Rank: Apprentice
Rating: 95%, 10 votes
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 07, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
all you have to do is find the jumper on the mother board and it will reset itself 100%
Solution #4
posted on Oct 27, 2007
Somewhat Helpful)
nightshifter
Rank: Wiz
Rating: 80%, 33 votes
Toshiba has known issues on BIOS passwords. call tech support immediately or visit askiris.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
jmorgan123
Rank: Guru
Rating: 90%, 1031 votes
This page includes backdoor passwords you can use to reset the bios password.
http://www.tech-faq.com/reset-bios-passw...
Was this helpful?
Yes
No
Solution #6
posted on Sep 21, 2009
Very Helpful)
igotit2
Rank: Apprentice
Rating: 100%, 2 votes
i have a Toshiba satellite M105-S322 and all i had to do is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Was this helpful?
Yes
No
Solution #7
posted on Apr 19, 2008
Not Rated)
kikeraba
Rank: Apprentice
Rating: 0%, 0 votes
hola,
La solucion para la M105, es de hardware.
Se saca la tapa de la memoria, sacas la memoria, levantas el covertor de la mother y te encontras con una inscripcion de clr-cmos y 2 barras que indican en el conector de la memoria los pines que hay que poner en corto para limpiar la bios.
HAY QUE SACAR LA BATERIA.
Pronto.
Suerte
Enrique MVDEO kikeraba
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens AMILO D-7830
Questions and Unsolved Problems for Fujitsu Siemens AMILO D-7830
Do you recommend Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook?
Answer
Answer
Whilst typing on screen the cursor drops to the bottom of the page at random - has anybody any idea... (More)
Answer
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS... (More)
Answer
problem: solfware not found. on my fujetso laptop computer.how to solve this?
Answer
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non... (More)
Answer
My new Fuj-Siemens Amilo laptop has a different cable socket to the earlier standard external... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu Siemens AMILO D-7830 ...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
