Question about Frigidaire FMV156EM Microwave Oven
Frigidaire won't run
My FMV156EM just stopped cooking one day. The timer will count down, but the motor won't run and cook. If I press on the door, the fan starts up and timer counts down, but yet again it doesn't cook. Any suggestions?? Do I get a new microwave or get it fixed?
  • gjdibrandi Dec 02, 2008
    just moved in...was running but when I went to use again, timer runs but unit not running...I need a user guide...
  • Frigidaire Master
  • 9,156 Answers
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
2 Suggested Answers
MicrowaveSvc
  • 9156 Answers
SOURCE: timer will run, but won't cook
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
My microwave oven will count down but will not cook. If you lift up on the door handle it will start cooking. I can't see anything broken on the door. Is there an adjustment for the door? If so how do you...
There is no adjustment to a microwave door. But, your problem is that the door has been bent downwards a little causing the door not to connect inside. There is two things you can do , one, replace the microwave or two, try to found a locale appliance store and see if you buy a replacement door. It would probley be cheaper to replace the microwave.
thank you.
Sincerely,
Cat2868
Jan 28, 2011 | Frigidaire FMV156EM Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
When I want to cook something the light turns on, the timer starts counting down, but the motor does not run. No cooking.
I have always found replacing the magnatron assembly as well as the high voltage fuse is normallly the best way to fix this problem. Good Luck,
Nov 15, 2009 | Frigidaire FMV156EM Microwave Oven
Same - the counter counts down, but doesn't cook.
Yes your door isnt aligning right when closed and the lower interlock isnt being made when shut. Look and see if where the door pivots if it is broke or sagging down.
Sep 11, 2009 | Frigidaire FMV156EM Microwave Oven
My FMV156CC
if you take your control pael off and look inside where the door closes there should be a setup with 3 switches the middle is the monitor switch and it is bad needs to be replaced.
Nov 27, 2008 | Frigidaire FMV156EM Microwave Oven
Timer will run, but won't cook
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Frigidaire FMV156EM Microwave Oven Logo
508 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
