Question about Eclipse CD7000 CD Player
No output when I play a CD
I have an Eclipse CD7000 and everything works fine except when I try to play a CD, it will read the CD and display the text put there is no sound output. The radio works fine and has sound. any ideas? Thanks
What kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Posted on Sep 24, 2008
6ya staff
SOURCE:
Rockford Fosgate stereo acting crazy. Don't get any sound when I restart the engine. Help!!
best fix is to look for a used eclipse rockford forthgate unit that works
Mar 01, 2016 | 2008 Mitsubishi Eclipse Spyder
Buttons not working on Sony icf-cd7000
Hello
Unplug the unit and replug it after 5 minutes or so. Then Hold Down the CLOCK/DATE until a short beep sounds. If this beep sound cannot be heard, be sure that the internal circuit has some trouble, and has to be repaired. Normally, any other button get strucked, there will be no response with other buttons. OK.
Nov 02, 2011 | Sony ICF-CD7000 CD/MP3 Clock Radio (Black)
I have an Eclipse CD7000 head unit. I touched the power lead (unfused) to the back of the deck. the deck will not power on anymore? Help?
It is possible that the shorting might have resulted in creating a damage within the set and it must be probed first with the power connected diectly , then the swithced power and tthe ground. now trace the power +12 to the main circuit after switched power is on.
If there is a line fuse you are lucky as much a fusible resisitor.
If there is power to mP then check for oscillations , the allied circuits.
If set powers up check the output IC,possible if the output has shorted the protecction canbe ON. so disconnect power to IC and check.
Sep 25, 2010 | Eclipse CD7000 CD Player
My eclipse cd3404 player is off and tells me to call 800SC502970 what do i do? happened after new car battery.
If you are the original owner, you should be having the CD which you played first. That CD acts as a key as an anti theft protection. However if do not have the CD then ring up eclpse and have your Serial Number ready at hand. They are the only ohes who can help you out to make a new key. This happens every time the battery is disconnected. So all the best............sodeep
Aug 03, 2009 | Eclipse CD7000 CD Player
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
How to hook up sirius radio with cd7000
all you will need is the eclipse ecl- sc1 module and a subscription and you will be off and running with this deck
Sep 24, 2008 | Eclipse CD7000 CD Player
ECLIPSE 5443 DISPLAY DONT WORK
Hi Rozz,
That is the LCD screen and the backlight has evidently burned out. See if you can find a broken Eclipse of the same model on Ebay and replace your LCD screen.
Mar 21, 2008 | Eclipse 5443
Eject button will not eject cd
Mine was stuck in there for almost a year until I disconnected the battery (for other reasons) and when I reconnected it, the CD finally saw the light again.
Jan 26, 2008 | Eclipse CD7000 CD Player
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Oct 16, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
Brand New Unit Will Not Accept ANY Type of CD
I am having the same problem but only with a KDC-MP335 unit. I installed it in a 1995 Jeep Grand Cherokee to the stock system, pretty easy install just matching colors for wires and everything works (Radio). but not one CD plays. it says reading and it acts as if it is playing the tracks but no sound... what is going on? did I mess up wiring it or something?
Oct 03, 2006 | Kenwood KDC-X890 CD Player
Eclipse CD7000 CD Player Logo
144 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
