Question about Belkin Computers & Internet
Setup adsl parameter error - Belkin Computers & Internet
    Director Badge:
    Uploaded 100 video answers.
  • Belkin Master
  • 142 Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Cruz reader r101 will not load web pages
Is your ADSL correctly set up for WIFI?
Have you got the encryption (WEP?) key to enter into the T101? Your ADSL will not connect unless the identical key stored in your ADSL parameter set are correctly entered from the 'keyboard' on the T101.
If you go into T101 Wi-Fi settings, you will see a list of networks, one of those should be yours, just connect to it.
Hope that is of some help, or just a pointer in the direction you want to go. -Good luck!!
Feb 11, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Jul 09, 2011 | Zebra 105SL Thermal Label Printer
I've got some problems with my zebra zm400 printer. It says error ribbin out
May 05, 2011 | Zebra 203DPI Printer
Router setup gets Error 302 message
Old configuration parameters are lost. Check with your service operator for a fresh config details to enable the router in gateway mode.
Oct 18, 2009 | Computers & Internet
Zebra 105sl printer shows Error Code: ribbon out Printer Idle: 60-16-3z after we moved it from a different location. However, we've been printing fine w/o ribbon for many years.
so u used the direct thermal label that doesn't need a ribbon ? check the driver at Printer & Faxes on the PC, change the print method on the printing preference from thermal transfer to direct thermal
Jul 21, 2009 | Zebra Printer 140-751-00000
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
Jun 23, 2009 | Acer Aspire 3610 Notebook
Setup won't go through - error
I had a similar problem, and how I fixed it, was I made sure the connection was working, so the pc end had right details, and then I turned it off, and then put in router, and when it started back up, it started up and connected straight away.
May 31, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
RE: NO ACCESS TO MICROSOFT SITES FROM ADSL/MODEM ROUTER OVISLINK EVO-DSL11
If your modem/router has a setup page, you may configure the MTU on it instead of configuring it on each computer. The modem/router's setup page can be accessed using the address 192.168.1.1 on the Internet Explorer's address bar or you may follow these steps.
1) Connect to the website integrated router by typing its IP address local (default: 192.168.1.1).
2) In the left menu, click on Show advanced Settings.
3) In section Hotel, please click WAN.
4) Please set the following parameters:
-- MRU = 1400
-- MTU = 1400
-- MSS = 1360
5) Click on Submit.
6) Click the Save Setting and Reboot and if necessary on Submit.
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Ps3 error
put in your ps3 hardware disk that came with your system in the box and switch back the parameters that way your system came with a setup disk that auto matically runs so you can reset your system parameters
May 05, 2008 | Sony Playstation 3 (PS3) Console
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
957 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
