Question about Citizen GSX 240 Matrix Printer
Cable What type of a connector cable does this printer actually use? What is the actual name of the end that connects to the printer? What is the actual name for the end that connects to the computer?
  • Zwoman Aug 31, 2007
    I know it takes a parallel cable but, does anyone know which one? There are tons of different cables out there.
  • 32 Answers
Is called a "parallel cable". If you search the web you found thousands of place where you can buy this or even build your own cable
Posted on Aug 25, 2007
SOURCE:
I need an adaptor to use withy musb port on labtop
Hi you need a 4pin connector however the manual does not state what type of 4pin cable. It would depend on the type of connector on the actual device.
If you could send me a photo of the actual port where the cable connects to the laptop. I may be able to help.
My email is: [email protected]
HOPE I HELPED ALAN
Jun 27, 2011 | Sharp Wizard OZ-770
I have a Brother 5 in 1 Multifunction MFC-3240C and wondering where you plug the printer cable in to the machine? Could you please tell me where the printer port on the printer is located. Thank you very...
This printer connects via USB cable and not thru a parallel printer cable. The USB connector is actually inside the machine. Here is a small image of where the connector is and a link to the quick start guide.
here is a link to the entire document
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_3240C_3340CN_EN_376.PDF
May 04, 2011 | Brother MFC-3240C All-In-One InkJet...
Error code = 6A00 whats the problem
ou should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. (Refer to the illustration below to confirm the USB cable is in the proper orientation.) It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists. Note: Some printers have a type-A USB receptacle on the front to connect directly to a digital camera. The type-B receptacle, on the printer, will connect to the type-A receptacle on the computer with an A to B USB cable.
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Jan 04, 2011 | Canon PIXMA iX7000 Inkjet Business Photo...
There wasn't a USB cord there. What cord shou8ld I buy?
Printer connection cables are not always included; this is something to watch for when purchasing new printers.
As an example, Lexmark sells a USB (2meter) cable for use with their printers. It has a Type A connector on one end (connects to computer) and a Type B connector on the other end (connects to printer).
See illustration here:
http://www.lexmarkshop.ca/product_info.php/info/p547_USB--2-Meter--Cable.html?XTCsid=8uf9jfg007037lui6nbrrvkko5
You should however be able to purchase a suitable cable at your local supplier; there are also on-line suppliers who are very reasonably priced.
Try to stay under 10 feet or 2 meters in length and ask for a cable with a Type A and and a Type B connector for use with an USB printer interface.
Trust this is helpful. Please vote.
Dec 30, 2010 | Office Equipment & Supplies
Lexmark X2470,all in one.what usb is required,as it is not supplied
Printer conncection cables are not always included; this is something to watch for when purchasing new printers.
See here:
Try to stay under 10 feet or 2 meters in length as ask for a cable with a Type A and and a Type B connector for use with an USB printer interface.
Dec 29, 2010 | Office Equipment & Supplies
I have the tew-652brp. What is the RJ-45 cable is that the one that came with the kit.
RJ-45 actually refers to the "telephone" type connector on the end of the cord, but it's just the Ethernet Cable that comes with the kit (better than the USB) Hope it helped.
Nov 04, 2010 | Computers & Internet
I've lost the cord that connects the printer to the computer. What type of cord do I need?
You need a standard USB printer cable. It will have a different type of connector on each end. The end that plugs into your computer is Connector 1: USB Type A Male
The end that plugs into your printer is
Connector 2: USB Type B Male
Jun 16, 2010 | Epson Stylus CX5800F All-In-One InkJet...
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
Hi, I have connected the printer to the computer with the network cable, both of the devices are switched on, and still the computer does not find the printer. I tried restarting the computer a couple of...
By network cable, you mean CAT5 or CAT6 actual network cable, or did you mean USB cable? If you are connecting directly from your printer to your computer with network cable, it would need to be a cross over cable, not regular network cable. If you are using USB cable, here is a link to Samsung for your ML-1630W operating instructions. Reference page 3.2 for using USB with software CD.
http://downloadcenter.samsung.com/content/UM/200911/20091120134236000/Guide_EN.pdf
Dec 06, 2009 | Samsung ML-1630 Laser Printer
What router do I use for the hp officejet 6110 All-in-one
You should put both computers under the same "groupwork" name .
to change this settings right click on MY COMPUTER the go to properties
then the go under the COMPUTER NAME tab. CHANGE the settings Look at PICTURE #1
When you choose the "workgroup" name make sure that you pick a unique name.youll probably want to use your name.look at picture #2.after changes are done your asked to restart once you have done this FIRST part let me know i can help you with the setup of the Nwetwork Printer.b07620b.jpgbdecea2.jpg
Nov 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Citizen GSX 240 Matrix Printer Logo
69 people viewed this question
Top Citizen Office Equipment & Supplies Experts
ksriramkrish
Norman Al-Anbar
Steve Allison
Steve Allison
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
