Question about Motorola Mobility RAZR V3
Voicemail i just got my razor and i dont know how to setup my voice mail-i clal my VM number and it says i have no greeting [ how do i create a greeting] or i call my cellnumber and it beeps buzy. what do i do? can you respong to this at thnkx, Lou.
    Brigadier General:
  • 7,752 Answers
Re: voicemail
You need to contact your service provider and have them assist you with setting it up.
Posted on Feb 24, 2008
0 characters
3 Points
1.From your Optimum Voice phone line, dial *86.2.Follow the simple steps to set up your voicemail password, create your greeting, and confirm your service choices.
Mar 12, 2016 | Cell Phones
I need to know how to set up my voice mail on my Blackberry 8310?
Voice mail is nothing to do with the phone, its a service provided by your mobile network provider. Usually the phone number is 123 or 121 or something like that. once you ring that number you'll have a menu system to create a new greeting message.
I think you have posted it twice why ?
Sep 26, 2008 | Cell Phones
How to set up voice mail
    To activate your new AT&T Voicemail Service by dialing your telephone number from the phone assigned with the feature, follow these steps:
    1. Dial your 10-digit telephone number and press * while the greeting message is playing. ...
    2. Create a passcode. ...
    3. Record your name. ...
    4. Record your personal greeting. ...
    5. Record your busy greeting.
    AT&T All In One(R): Voicemail Services: Getting Started ... AT&T
Feb 08, 2016 | Cell Phones
How to change voicemail on a galaxy 5
  • From the Home screen, tap , then tap Call icon.
  • Follow the tutorial to create a password, record a greeting, and record your name.
Note: These steps may be different depending on your network.
Accessing Your Voice Mail
  • From the Home screen, tap Call icon, then tap Voice Mail icon. You may be prompted to enter a password.
  • When connected, follow the voice prompts from the voice mail center.
Accessing Your Voice Mail From Another Phone
  • Dial your wireless phone number.
  • When you hear your voicemail greeting, press the asterisk key on the phone you are using.
  • Enter your password and you are connected to your Voice Mail.
May 18, 2015 | Samsung Cell Phones
Galaxy s three not working voicemail
  • Standard Voicemail
    • 1 Press the "Phone" button from the Home screen and then hold "1" on the keypad until the Galaxy S III dials voice mail.
    • 2 Enter your wireless number -- without the area code -- to sign in to your mailbox for the first time.
    • 3 Follow the voice tutorial to create a personalized password and greeting for your account.
    Visual Voicemail
    • 4 Touch "Apps" from the Home screen, and then scroll down to and select "Voicemail."
    • 5 Select "Personalize Now" to connect to your mailbox. Follow the voice tutorial to configure your account.
    • 6 Touch "End Call" to return to Visual Voicemail and view and listen to the messages in your inbox.
  • Sponsored Links
  • Read more :
    Nov 12, 2014 | Samsung Galaxy Cell Phones
    How do I set up voice mail on an iphone
    Adding Voicemail for the First Time
    1. Tap the "Phone" button on your iPhone.
    2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
    3. Click "Save" to set your recording to your voicemail greeting
    Recording a New Greeting
    3. Choose "Greeting > Custom."
    4. Select "Record" and begin recording your voicemail greeting.
    5. Hit "Save" to set your recording to your new voicemail greeting
    Dec 06, 2011 | Apple iPhone Smartphone
    I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
    Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
    I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
    Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
    Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
    For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
    Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
    Almost all mobile phone service providers has a so called "Voice mail Access Number"
    This number can be dialled and goes straight to VM.
    Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
    Voice prompts might also ask you to enter your VM PIN(if seup).
    Just follow Voice prompts and you're good to go.
    Hope this helps.
    Sep 15, 2011 | LG CG225 Cellular Phone
    I don't know how to set up voice message
    If you mean setting up voice mail out-going message, then see below (for AT&T cell service). The phone will dial the voice mail center for you after you set it. Then it will check the number of messages on the system. Press Menu > Messaging > Settings. Then select Voice Mail and enter the phone number for the call center. Then press the AT&T button to exit.
    To listen to the messages, press and hold 1 or press Menu > Messaging > Voice Mail. Then the number set above will be dialed.
    To set up the voice mail box, start as you would for listening to the messages above. Note: you must use your wireless phone and be inside the AT&T coverage area.
    To set up your voicemail box:
    1. Follow the prompts to create and enter a 4- to 15-digit voicemail password.
    2. Record your name and personal greeting, then press the # key
    3. After completing the setup process, press * to return to the Main menu.
    See for more information.
    For another provider, see their documentation.
    To create a memo for yourself, press Menu > Tools > Voice Memo (or if using the advanced menu, Menu > My Stuff > Tools > Voice Memo). Then press Options > New (or Create New, if you have created one before). Press Re-rec to record and pause to momentarily stop recording. Press the AT&T button to stop recording. Press Play to play back a memo and the AT&T button to stop play-back.
    I hope this helps.
    Jan 29, 2011 | Pantech breEZeTM Cellular Phone
    Voice Mail recording
    the voice mail key is the #1 key on the keypad as well it should have an envelope icon on the keypad as well, just press and hold the #1 key and follow the step by step instructions to setup you voice mail.
    Sep 28, 2008 | Sony Ericsson W850i Cellular Phone
    Razr v3 setting up voice mail
    Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
    Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
    Dec 17, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility RAZR V3 Logo
    108 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    Chris Hunt
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
