Hi, You need to get the ''installer code'' from your alarm company in order to go into the programming of your system and do the change...and of course the programming manual, please be advised hat if you make any change to your system and something goes wrong your alarm company could charge you in order to fix the problem. Legally, IF you bought the system, you are entitled to get the installer code, the alarm company can't even think to argue about that!.
You can do this, you need the installation manual to set it up and the installer code. Should take you twenty minutes or so. http://www.ge.com/products_services/security.html You will have to sign up to get access. Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Security Simon 3 Wireless
I have had a working GE Simon 3 for a couple of years. After a recent house remodel, I noticed that...
(More)
I have had a working GE Simon 3 for a couple of years. After a recent house remodel, I noticed that the alarm speaker on the panel has been disconnected from the circuit board. There are two possible pairs of pins on the board that the speaker could connect to. When looking at opened panel, there is a pair of pins at roughly 11 o'clock from the speaker, and a pair at roughly 10 o'clock from the speaker. Which of these should I connect the speaker to? Thanks.
I have had a ADT Security system for years however I do not have actual service with ADT for maybe a...
(More)
I have had a ADT Security system for years however I do not have actual service with ADT for maybe a year now but we still set the alarm at night. Recently it started beeking and kept saying low battery. I replaced the battery and it still is not working properly and does not recognize any of the sensors............
My new GE Simon is programmed and ready to go but even though it says doors and windows are armed....
(More)
My new GE Simon is programmed and ready to go but even though it says doors and windows are armed. Nothing happens when I open the doors and windows in armed mode. No sound, no alarm. I know the sound works becuase when I try to access the panel without an access code it trps the alarm. Also, key chain fobs fail after a few hours. They work fine then lose the code. Batteries have been replaced.
