Question about RCA F32450 32" TV
RCA F32450 TV will not power on. When I press the on/off switch I get a flashing power light. When I unplug the set, I hear both speakers thump as it powers down. No high voltage. Thanks Truman McManus
  • 140 Answers
Re: RCA F32450
I have a PDF file of the Training Manual and Troubleshooting flowcharts for the ATC113 chassis- if you want it,let me know where to send it.
Posted on Sep 05, 2007
    Brigadier General:
  • 6,966 Answers
Re: RCA F32450
Hi, It appears that your unit has switched to protective mode (hence also no HV). When you unplug the set and "speakers thump", that would mean that the low B+ is still active and your SMPS is good. Your post "No high voltage" leads me to believe that you have a fair idea of working inside a TV. Should you venture to do-it-yourself (of course the standard precaution when working with TV units specially HV section), try checking: 1. an inductor/coil supplying the main B+ to the horz (probably L14???), resolder fully; 2. the Horizontal circuitry with special attention to the HOT (TL0?) and the FBT. It may also be a good idea to have the FBT ring tested. Other than above, it's the usual check with your VOM with attention to B+ line. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 27, 2007
0 characters
3 Points
Power light flashes on and off then stays on but no pitcher or sound
power light flashes on and off then stays on but no picture or sound
Oct 01, 2010 | RCA F32450 32" TV
Tv on but cannot use remote
Have you tried unplugging it for at least 5 minutes?
Jan 10, 2009 | RCA F32450 32" TV
RCA 32V434T Flashing Red Light
Flashing protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
RCA Model #F32450
unplug and call tech.
Jun 22, 2008 | RCA F32450 32" TV
RCA F32450 TV problem
color ic on the blink.
Jun 16, 2008 | RCA F32450 32" TV
RCA Model F32450
hot-replace and solder all leads to smt transformer.set should power up.also flyback may have shorted.rca has a repair kit for this set. all necessary parts.
Apr 15, 2008 | RCA F32450 32" TV
RCA F32450 ATC113 chassis Dead & Squealing
IHVT # 257805 or ASTI 2078 = 20.00.......................T.
Dec 02, 2007 | RCA F32450 32" TV
RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Oct 31, 2007 | RCA F32450 32" TV
No picture or sound
Classic power supply or horizontal output problem. Take it to a servicer.
Oct 18, 2007 | RCA F32450 32" TV
Is this a Toshiba or an RCA? The problem description does not seem to be right. From what your saying though it sounds like there isn't any high voltage. If you are not qualified to work on TVs you probably should take it to a shop for repair.
Jun 21, 2006 | RCA F32450 32" TV
RCA F32450 32" TV Logo
76 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
