Question about Kenwood XD-A53 Shelf System
Cd malfunction i have akenwood (xd-a53)mini hi-fi component with 3cd changer the cd tray works very good but when i put a cd i heard amottor soud but the cd not works ,i changed the the for many times but the problem is the same but sometimes when i put a cd and press the forword button,the cd works for some seconds. i tried to rest the component by holding the enter key and plug the power cord again it gives me amessage initializing and after that it gives me another message says(X ERR )help me please.
2 Suggested Answers
  • 15 Answers
SOURCE: 3 CD player Kenwood
Dismantle unit and try to open unit look to see if a motor is running maybe it is being droven by a belt or a gear is worn the belt may drop inside the unit. If the belt is worn change it.
Posted on Aug 10, 2008
SOURCE: i have a kenwood compact hi-fi system xd-751 the 3
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
Posted on Feb 10, 2010
0 characters
1 Points
MHC-gx450. Why won't the tray open?
Apparently a mechanical issue. Cannot tell you without looking at it. Sorry.
Jun 20, 2015 | Audio Shelf Systems
CD unit unit displays ''No Disc'' when there is a disc in slot 1
What does it do if you put 3 discs in and select each one? You don't say what it does with the other two trays. It would help to know that they work. If not, you have a bigger issue. Let me know.
Apr 03, 2009 | Sanyo Audio Shelf Systems
3 CD player Kenwood
Aug 07, 2008 | Kenwood Audio Shelf Systems
How to re-install cd shelves inside changer
What brand and model stereo system are you talking about? Setting back the cd mechanism in some players can be tricky.
Jan 26, 2008 | Audio Shelf Systems
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
Cd changer malfunction
I know that this sounds like a crazy solution to Pitsy`s CD problem but today i took a chance by using my lawn gas blower. First I opened the drawers of my CD turntable and also my cassett doors. I put ear plugs on and blasted the air into the openings. All i can say is it is now working fine !! Lou F.
Aug 15, 2007 | Sharp CD-XP120 CD Shelf System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Kenwood XD-A53 Shelf System Logo
Top Kenwood Audio Shelf Systems Experts
Are you a Kenwood Audio Shelf System Expert? Answer questions, earn points and help others
