Question about Emerson ET-20F7 19" TV
Remote not working
Changed batteries and remote still doesn't work. Had problem about 2 wks ago, unplugged tv, replugged and everything worked. Tried universal remote and it didn't work either. Is is something in the tv? TV is about 8 yrs old. Took remote apart and everything looked ok. TV workd fine but you have to do everything the old fashioned way. You have to actually get up and press the buttons! What is the world coming to?
  • jimpersram May 11, 2010
    I have a MAG TV (model MA32EF1AC)two years old. The remote does not work; I changed batteries; unpluged and repluged; cleaned everything and it still does not work.The TV works when I do it manually
    New Friend:
  • 76 Answers
Sometimes dust is accumulated in tv remote receiver sensor. This will give you the malfunction. Because your statement says TV is about 8 yrs old. Better solution is make one general service. If you have remote checker check the TV original remote working or not. We say universal remote, sometimes even technical person does not know how to use. Because in each and every brand and model there is a secret code to initiate the version. So better make one general service and check in your original remote it is working.
Posted on Aug 25, 2007
8 yrs old lol
Posted on Sep 28, 2008
6ya staff
SOURCE:
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
I have a dish network echostar remote control (20.0 IR). When I press any button that normally controls the satellite box, nothing happens except the green "sat" button on the top left lights...
Unplug the satelite box and replug it back like about an hour later.By letting the box resetting and upgrading it softwares the remote should work again now.
Dec 25, 2010 | DISH Network IR Remote Control
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Re: 322 DTV Receiver - snowy screen on tv 2
Lets check the modulator set up at the main location TV 1. Press menu - 6-1-5 this will display how the TV 2 IS SET UP. It should say 22 air and if not use the arrow keys on the remote to change that info. Once you are done click done and go to the TV2 and see if it is working. It should be if you are set to view air or antenna channels on the TV2. If not there needs to be a few more things done to isolate the issue. Let me know and we will go from there. Thhanks for using Fix Ya.
Apr 11, 2009 | DISH Network 322 DTV Receiver
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Remote control volume
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Aug 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
TV-not working
How about the buttons on the side of the tv?? work?? if so the trouble is in the remote: if they don't work either, the trouble is in the set = goose cooked-- sorry
Jun 17, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
1,172 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
