Question about Epson Stylus CX6000 All-In-One InkJet Printer
Message on Epsom Stylus DX6000 reads E-02. How to fix?
Poor text print quality. Followedinstructions on how to clean print heads, but message E-02 came up. Cannot get the printer to do anything now. E-02 comes up every time I switch on.
  • lyon119 Mar 28, 2009
    Thanks - it turned out to be a faulty cartridge.
  • 163 Answers
E-02 is an ink cartridge error, possible causes incude faulty ink cartridge chip, incorrectly installed cartridge, dirty contacts, ribbon cable not fitted correctly to carriage or faulty CSIC board in the carriage.
Your first step would be to remove all of the cartridges and clean the contacts and cartridge chips with contact cleaner or alcohol wipes. Refit cartridges ensuring that they all click into place and check the ribbon cable into the carriage is secure.
Hope this helps, please take a moment to rate this solution. Thanks.
Posted on Mar 26, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Poor print quality, not fully black with white lines through text/images.
The white lines are caused by some CLOGGED ink-jets that are not spraying the ink onto the paper at the appropriate time.
Start the Epson printer-software, and run a "print-head-cleaning-cycle", to try to UNCLOG those ink-jets.
Oct 17, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
I have error code e 90 on my epsom printer
Generally the fix for most "e 90" error messages on Epson printers is to check under the hood of the printer for something that is there and shouldn't be, eg. glue stick, pencil, paper jam, etc. Most e 90 error messages are solved by simply removing something that shouldn't be there. If, in fact, that doesn't fix it, you should try removing the printer catridges and re-setting the printer. If this still does not fix the problem you should try contacting the Epson Customer Service department and try and get a replacement printer, considering this is surely a hardware issue.
May 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The black ink in my Epson dx6000 won't work. I've wasted so much ink cleaning the print head. HELP!!! Please!!
You could try this Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Hope it works for you. Worked on my HPc6180
Apr 28, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Print quality problems
First off replace the ink cartridge.
then look into the menus of the printer and perform the head cleaning procedure.
Most of the time what you are describing is simply a cartridge out of ink and not showing empty
Nov 14, 2007 | Epson Stylus DX4850 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
5,370 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
