Question about Lexmark P4350 All-In-One InkJet Printer
My printer only prints the first page
When I go to print something with multiple sheets it only prints the first sheet and that is all.
  • Nitwon Apr 19, 2009
    i've made absolutely sure that it's set to print all pages of a document, and only the first comes out. when i choose "print last page first", it prints the last page, and that's it. The printing dialog does actually say "printing (page 1 of 9)" then 2 of 9, 3 of 9 etc, so that recognises all the pages, but only the first prints then it says printing completed, basically. sometimes the printer will make extra noises as if it's thinking about feeding another page through, but it doesn't.
You may want to verify that your in your printer menu it is set up to print the entire document not just the screen view document. If it is on the screen view it will only print what you can currently see, not the additional pages.
Posted on Aug 24, 2007
    New Friend:
  • 3 Answers
My brother HL-5130 only printed one page.
I am using windows 7 64bit
Go to printers left click your printer then go to adjust print options
click advance
Click page settings
tick reverse print
Scaling free
Posted on Aug 06, 2013
    New Friend:
I have the same problem with my canon mp450. It just started doing it after 2.5 years of printing. I made no changes in the drivers,settings or firmware. No matter what I do it only prints one and then motions like its printing others but spits out blank pages. Ink looks good on the one that prints.
My guess is that its one of those annoying vista updates. I downloaded 4 security pathes the other day.
Posted on Jan 06, 2010
SOURCE:
  • 244 Answers
SOURCE: why do all pages print onto one page when i hit the print button in a multipage document
Hi scottish,
Absolutely, there is no problem with your printer. Please try to check your document it is possible you changed the setting of your page setup. Try to print a new document probably two pages just for testing, I am sure you can print it exactly what you need.
If you still experience the problem, please post again any further question's you need.
Best regards,
Philip
Posted on Oct 24, 2007
  • 39 Answers
SOURCE: Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
Posted on May 22, 2008
  • 4 Answers
SOURCE: canon HL 5040 printer grabs multiple papers to print
try one sheet at a time that may work.
Posted on Oct 21, 2008
  • 76 Answers
SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Posted on Nov 21, 2008
  • 101 Answers
SOURCE: laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Posted on Mar 07, 2009
Multiple pages in one sheet?????
I tried with MS Publisher and it worked real fine!!
Jul 28, 2009 | HP Photosmart C5280 Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
have you checked the manufacturer website for Firmware or software updates? i know you said you re-installed it but there's a chance if it's with the CD that came with the product, it may be out dated or buggy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
Apr 02, 2009 | Computers & Internet
Laserjet 3015 is printing multiple pages on one sheet
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Printing multiple pages per sheet
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Xerox Phaser 6360 Laser Printer
Nov 21, 2008 | HP LaserJet 3380 All-In-One Printer
May 22, 2008 | HP LaserJet 2200 Printer
Lexmark P4350 All-In-One InkJet Printer Logo
12,088 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
