Question about PSC Quickscan GP5385 Handheld
GP5385 incompatible with EAN 13
Hi all... I want to ask, why PSC GP5385-17304236 can't read EAN 13 code? Because i've tried with many others code such as code 39, it worked well. Best Regards, Akiong
  • Oeytjuikiong May 02, 2008
    Woi ajat tai..... ngapain lo posting sendiri trus ngeadd sendiri??? dah gila lo ya??
    woii  si ajat itu nama cinanya akiong....
    Sudrajat = Akiong
    = tai
  • Anonymous Mar 27, 2014
    ean-13=a
    Problem Solver:
  • 20 Answers
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Posted on Aug 25, 2007
SOURCE:
Enable Leading Zero in Gryphon M130
Can you show us the printed numbers before going further?
Oct 05, 2014 | Datalogic GRYPHON M130 C Wired Handheld...
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Quickscan psc GP5385-need a program manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
Caps Lock settings are on pages 36 & 37.
Label_Guy
Oct 02, 2008 | PSC QS6000 Plus Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
It doesn't read!!!
is this a spam or something?
Jun 24, 2008 | PSC (22000-0011050-60) Hands Free
I need an owners manual
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Programming GP5385 to scan 20 digits
Dear Huygen, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Jan 19, 2007 | PSC Quickscan GP5385 Handheld
PSC QuickScan GP5385-104342 RS-232 / DOESN'T WORK!
I think the problem you all are having is that this model of scanner requires a "decoder" to work correctly. It is another box which goes in-line between the scanner and the RS-232 port or ps/2 port of the pc. I'm not 100% positive about this, but I am pretty sure this is the problem. You need to look on e-bay for a psc barcode decoder.
Dec 15, 2006 | PSC Quickscan GP5385 Handheld
PSC Quickscan GP5385 Handheld Logo
346 people viewed this question
Top PSC Computers & Internet Experts
Thomas F. Schneider
Ekse
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
