posted by Doug 34 on Aug 24, 2007
I'm using a RCA cable that plugs into the base (in the AV port)for my camera and have it hooked to the TV inputs so I could show the pic's to my family. When I have it all hooked up the screen on the camera is black and nothing shows up on the TV. Can you help.
Best Solution
posted on Aug 26, 2007
Playing Back Images/Video Clips on TV
You can also playback your images on a TV screen. Before connecting to any device, make sure to
select NTSC/PAL system to match the video output system of the video equipment you are going to
connect to Vivicam 5340s, then turn all connected devices off.
1. Position Vivicam 5340s on the cradle.
2. Match the docking connectors and carefully insert Vivicam 5340s
until it fits in place.
3. Connect one end of the A/V cable to the A/V terminal of the
cradle.
4. Connect the other end to the A/V input socket of the TV set.
5. Turn the TV and Vivicam 5340s on.
6. Playback the still images/video clips.
The method of operation is the same as playing back still
images and video clips on Vivicam 5340s.
I hope this helps:)
cradle.
I hope this helps:)
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Vivitar ViviCam 5340s Digital Camera
Email this problem
Email this problem
Can you Help with these Digital Cameras problems?
My control buttons won't work
Help me out..The camera is new... Answer This...
red squiggly line in center of...
Every time I print out... Answer This...
Vivtar Cam 5340S
Vivtar Cam 5340S
My Vivtar 5340s will take a few... Answer This...
lens wont open
lens wont open
when I turn on the cameral the... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
