Question about Oritron DVD4119
Will not read.
Whenever I put a Dvd in, it will turn as if it's reading but it will say error or cannot read disc. I've cleaned the lense but it still does not work. Where can I buy a new eye for my Dvd player.
    Problem Solver:
  • 10 Answers
Almost any electronic store can help you but i would try factory customer support first it probably cheaper to just buy a knew player
Posted on Aug 25, 2007
Hi, My S-Master 5.1 Digital Amplifier can't read any DVD and every time it give a no disc error, i tried many DVDs with no good except one time it worked fine and after that the same No Disc error every...
Most disc read errors are caused by dust or dirt on the lens of the DVD player. You should follow the cleaning instructions. Or watch a YouTube video on cleaning DVD lenses.
Oct 12, 2013 | Sony TA-N9000ES 5-Channel Amplifier
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
Xbox is not reading the discs
man this is your xbox dvd drive failuer.its not a very big problem if you can.just open xbox.plug out dvd it carefully.clean its lense.
other wise buy a new lense from ebay of your same dvd drive is written on your dvd drive case.your xbox will b fine.i also had the same problem
May 19, 2010 | Microsoft Xbox 360 Console
DVD inserted tries to read disc eventually message says no disc
First purchase disk cleaner disk from nearest computer shop then put it in dvd then play it so it clean dust from dvd lense.
If still it not read disk then you have to change dvd lense.
If your dvd is in warrenty take it to service centre and they replaced lense and repair it.
Let me know if you need more assistanse.
Sep 07, 2009 | Televison & Video
My ps2 makes a clicking sound and gives "disc could not be read"
I had the same problem with mine. it would play the ps2 games just fine but when i put a DVD in, it would click and keep saying reading disc.. i took it apart and gently cleaned the lense with a qtip and now it works fine
Aug 21, 2009 | Sony PlayStation 2 (PS2) Console
Philips Magnavox MWD200G DVD Player
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Mar 09, 2009 | Televison & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
LG V8824w DVD/CD - Disc Error
I bought a lg lst3510A at a yard sale for 20 bux. Lady said that it was new and had never been used. Plugged it in and got disc error when trying to play a dvd. I removed the cover and gently slid the lens pickup to the far back I DO MEAN GENTLY.... IT SEEMS LIKE IT HAD LOST ITS HOME POSITION. This worked for me. IF YOU TRY THIS MAKE SURE THAT YOU UNPLUG THE DVD PLAYER FIRST. Good luck and I hope this works for you.
Mar 16, 2008 | Televison & Video
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
120 people viewed this question
Top Oritron Televison & Video Experts
jairo sanchez
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
