We have an Epson ELP 3000, just replaced light-bulb. When turned on, you a a clicking noise that continues, and all status lights continue to flash. If I remove the fuse, no power comes on. Insert fuse back in, same clicking and flashing results. I have not tried replacing with a new 250v, 6.3a fuse. Also, the fan does come on. Not sure where the clicking noise is coming from. And, not sure how to separate the case in the middle seam to get inside.
This unit was donated to our church,, just taking another look at.
Thanks in advance for all your help
Dave
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
SOURCE: epson elp 7200 projector
check power supply (electricity)in wall outlet by another appliance.
--check for defective power cord-test with another one.
=apply good brand of contact cleaner over power switch.and press it many times.
--check blown power fuse and change it with same rate if it is defective.--if all above did not fix the problem pass it to service center.
SOURCE: Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
SOURCE: need to replace the bulb in an epson e71 projector
Hi, this is pretty straight forward. Make sure the projector is off and cooled. On the bottom is the Lamp cover, press the two tabs and lift the cover off. Loosen the two retaining screws and pull the lamp assy upwards to remove. Fit the new lamp and tighten the screws then rfit the lamp cover. You will need to reset the Lamp hours using the "About" menu after turning back on (Not the "reset all" menu).
The user guide can be downloaded from Epson support:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=KBTjt4A8+KgSfbEGuimYvDcGHmpVV+Ko
SOURCE: My EPSON Powerlite 730c projector doesn't power up
epson will not sell parts to anyone who is not an authorized service center. sorry. if you can get the part from an asc, then you can replace it.
SOURCE: Epson 5300 not powering up
Did you fix this problem? If so, please let me know as I have the same problem.
thanks
