Question about RCA CC4352 Camcorder
RCA cc540 VHS camcorder
My camcorder comes on,the tapes wind& rewind,the only problem that I have is that I put in a new battery(the old one finally played out),but I can't get the viewfinder to come on,after removing the lense cap.it won't even show that a battery is installed,the battery is a replacement battery for this kind of camcorder,yet it won't work.the battery charger works find,what's up? please help me Barbara massey annmassey1_2000@yahoo.com
    Brigadier General:
  • 6,966 Answers
Hi, Try running the camera using the AC power (charger) instead of the battery. If the viewfinder works then, it is possible that the replacement battery somehow is not suited for your particular brand/model and is not capable of supplying all the need voltages/power. Try continuously charging the battery for 16 hrs at least to see if this will correct the problem. If even in using the AC power (adapter) instead of the battery, the view finder is still off, then you have a camera fault. Normal problem for this is the thin flexible flat cable that attaches the screen to the electronics inside the camera. In some case, it is the backlight of the display that is at fault. Either which would require the services of a qualified professional. Hope this be of some help/idea to you. Good luck and kind regards.
Posted on Aug 24, 2007
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
Rca cc540 video vhs camcorder manual
I have an owner's manual for an RCA CC412/540/542. This is not a schematic; just an owner's manual. Almost new; probably used one time.
Apr 04, 2013 | Video Cameras
Rca540 camcorder will not show tape in eye pc unit runs but no picture in view finder
Is there a eletrical board that controls the opening & closing of the lens in front of the camcorder?
Aug 29, 2012 | RCA Pro Edit Camcorder Model Cc540
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
Code: 31:23....please reinsert tape. everytime i switch it on.
dear
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Jun 22, 2009 | Sony Handycam DCR-TRV265E Digital...
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
VHS tape
is it a specific one particular tape? Or is it that all VHS  tapes that you put into the VCR or Rewinder do not rewind? Do clarify
Oct 24, 2007 | Optical Coating Model 108 VHS VCR
Handycam CCD-TRV68 control panel/tape door acting like it died.
In order to solve this problem please order the control switch block (control pad) pn: 147642411. If you need more info please advice.
Mar 28, 2007 | Sony Handycam CCD-TRV68 Camcorder
Cannot get Tape to into camcorder
Have you tried using the cleaning tape ?
Jun 02, 2017 | Sony Handycam CCD-TRV107E Camcorder
RCA CC4352 Camcorder Logo
738 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
