Dell Motherboard
Problem for Dell (8N816) Motherboard
Winbook N5/Dell 2650 Fans stop working
By qoalzm234 on Mar 26, 2009
The cpu (jp16) and back panel fan (jp20) both stop running after a few seconds. I had this problem repaired under warranty in 2004, the problem happened again after a while. There is no warranty now. Can I replace the faulty (sensor?) myself. I have the laptop stripped down in case the MB needs replaced. There are red, black and white wires going to the MB, what would the voltage be supplied to each. One would be 5v. I'd like to repair the laptop if I can it works well. At present I have two large cooling fans behind and a usb powered fan/base unit it sits on, but this is a hassle.
Thanks for any help.
Colin
Same Problem
May 18, 2009
-   Hello: I am having the same problems with the fans on a Inspiron 2650. I bought a used mb off of ebay and installed it but the fans still don't run. The cpu fan runs about 10 seconds when 1st booting but stops and doesn't run after that. The cpu fan should run all of the time shouldn't it? I did a continuity test on the old motherboard. I checked from where the black wire from the cpu fan plugs in to ground and it showed continunity. I called Dell about the first mb and they said it would be a mb fault if the fans were good. I used a 4.5 volt dc power supply to test the fans and they run.
Thanks, Jim -   jimpeoples1
Solution #1
posted on Mar 26, 2009
Not Rated)
Compurepair
Rank: Wiz  Dell Expert
Rating: 84%, 797 votes
you could do a continuity test on the black. If it,s earth/ground.
then add a wire to ground it constantly. the fan will most likely run constantly at full speed. bypassing any sensor.
This is only a suggestion, but may solve your problem.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (8N816) Motherboard?
Answer
Answer
open medion akoya E7330 pc case
Answer
i want to be audio drivers for pi945gzd motherboard please tell me how can i download this drivers... (More)
Answer
Where would I get a manual or full spec for a SCI36-r13 Dell motherboard can't find anything on... (More)
Answer
i need to know the diferent pins on the mother board so that i can convert another fan in the board
Answer
My Dell Inspiron works perfectly fine on the dock. When I use it away from the dock, though, the... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
