Question about JVC DR-MV1SUS DVD Recorder / VCR Combo
Machine locks up flashing "Loading"
When this happens I can't even turn off the machine. Unplugging it doesn't make a difference either. This has happened before and after many hours the machine seems to clear itself. This time it has been blinking "Loading" for three days with no end in sight.
  • clahookem Aug 25, 2007
    Unfortunately over a year...I have gotten a lot of use out of this machine. It always had this issue but always cleared itself. But progressively took longer and longer to clear and now isn't clearing at all. The "load" blinking light has gone but the DVD selection light is now flickering and it will accept no commands. I think it may be completely fried this time.
    Problem Solver:
  • 10 Answers
Firmware problems how long have you had it
Posted on Aug 25, 2007
SOURCE:
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
Childlock flashing unable start machine
Hi there, without some details of the make and model of your machine I can't tell you what buttons to press to perform a reset of the machine, however, this is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up. Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Aug 08, 2011 | Washing Machines
Door won't open on my wd-8015c washing machine
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Jul 22, 2011 | Washing Machines
I turn on the mashine programme wool and turned it on but my little one pressed the buttons after it and now there is a key on the display, the button "Start" is flashing but when I press it it...
Your machine has (quite correctly) operated it's child safety lock.
Your manual should tell you how to re-set it, however, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and you should be able to start the program again as you would normally
Jul 19, 2011 | Washing Machines
MACHINE LOCKED, HOW CAN I OPEN IT
Jul 08, 2011 | Samsung Washing Machines
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
Control lock
look closely at the control panel there is a button marked"control lock hold for 3 secs." probably a small pic of lock on it as well, simply hold for 3 secs to release it,
Jan 10, 2009 | Washing Machines
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
JVC DR-MV1SUS DVD Recorder / VCR Combo Logo
110 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
