Question about Epson Stylus Photo R220 InkJet Printer
Printing my own pictures
I want to select my own pictures for cd printing from scanner/camera/desktop or other folder but don't seem to be able to. How do i select my own pictures or is it not possible?
    President:
  • 1,114 Answers
I use the Epson Print CD software that cam with my printer. If you refer to the numbers in the attached picture I can show you how to select your own pictures to print on CD. 1. Select the "background" icon in the side bar. 2. Choose "select image" 3. Choose "file" & browse to the folder where your pictures are. 4. You can also choose to import the clipboard if you copy an image from another application or choose "twain" to get images from your scanner or camera. In the example I chose the "sunset" picture for my CD. Try the above & let us know how you get on! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 25, 2007
SOURCE:
How to use my sms card
If you camera came with a cable that has a flat end (USB PORT) you can plug it into the computer and turn the camera on. The computer will recognize it and give you options to open the files on it. You can look through the camera files just like you would look through any disk files or usb flash drive files.
Once you find your camera pictures, I would suggest opening the MY Pictures folder on your computer. If you want all the camera pictures within one folder within the My Pictures folder, then first create a New Folder and give it a name. If you don't care and just want them spreaded all within the My Pictures folder then you don't need to create a folder within the My Pictures folder. You can drag and drop the pictures from the camera you want to the My Pictures or New Folder you created, or you can click Edit at the top of the camera window and select copy then go to the My Pictures or New Folder you created and click Edit at the top of it's window and select Paste.
If you want all the pictures from the camera, then you can select Edit at the top of the camera window and then SELECT ALL, then Edit followed by Copy, then go to the MY Pictures or the New Folder and click Edit then Paste.
Apr 15, 2012 | E-Machines eMachines Desktop PC
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Where can i get the cd so i can download pictures off of my coolpix 5700
If you use a separate card reader and download to a folder you create on your desktop, you don't need a cd.
Oct 24, 2011 | Nikon Coolpix 5700 Digital Camera
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
From
Scan a document.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I lot CD for my 1-2mp Samsung digital camera to upload on pc. how to upload this now
no cd required.
plug the camera to the computer and turn on, if camera asks select PC.
on computer open My computer or computer folder and then find the removable storage device which is the camera, inside you will see DCIM folder and then your pictures you are free to copy, print, email, etc these pictures from there to your computer etc.
Jan 17, 2011 | Samsung Cameras
How do I scan on a Epson Stylus DX8400
Go to your computer icon on you desktop or start menu and click on it. It will show you folders, files and drives on your computer, scroll down until you see scanners and cameras and double click on it. If you Epson Printer scanner is installed properly, (which if it's printing, it is) select from the dropdown menu > it will say Microsoft Scanner and camera wizzard, click on that, click OK and it will open up the scanner wizzard. Click Next, place your document you want to scan on the glass facedown and select your option e.g. colour picture and select preview, when you are happy click next and it will scan the document, select the location you want it storing and save.
Lisa
Apr 20, 2010 | Epson Stylus DX8400 All-In-One InkJet...
How do I use the scan option on the C6280 to scan a document on my desktop. I can print to the printer but cannot figure out how to set it up to scan
First, make sure all of the drivers for your printer were downloaded from the CD that came with your printer and make sure your printer is connected to your computer and turned on..
Second, if you are using a Windows PC, Click on:
Start > All programs > Accessories > Paint
Third: When the Paint program opens, in the top toolbar click on, File > From Scanner or Camera > then select your printer by clicking on your printer's icon > then click, OK.
Fourth: Place the document you wish to scan on the glass of the scanner and click on: Scan.
The document will be scanned and automatically sent to the Paint program.
Fifth: Click, File > Save as > (name the document) and save it in your Pictures folder.
You can now close the Paint program and open your Pictures folder. Click on the document you scanned to view it.
Mar 29, 2010 | HP Photosmart C6280 Printer
I have a cd with pictures that came from my camara not a digital but i want to upload and save these pictures on to mu computer and im not getting an easy way to do this please help
Place the CD in the CD drive of your computer. Go to My Computer and double click on the CD drive (it maybe the D drive or E drive it depends upon your computer setup).
You can then open the folders on the CD disk (the folders may contain the photos) or the photos maybe not be in a folder. You can then Copy and Paste the photos from the CD to a folder on the hard disk of your computer.
Sep 17, 2009 | Compaq Presario 5000 PC Desktop
How to download photos from ex-z60 to laptop or desktop pc
connect the usb cable to your pc and camera, turn on the camera, select PC from the menu that comes up on the camera. now on your computer, open my computer from your desktop or from start menu, find the camera drive, if you are not sure which one it is, turn the camera off, press f5 on the my computer window and see what dissapears, then turn the camera back on, and press f5 again now what appears again, thats the camera drive. inside you will find folders and your pictures in one of the folders, you can copy them to your computer or print from there. best to copy them all to your computer, right click on the folder and select copy, then go to any place on your computer for example my pictures then right click on empty space and select paste.
Jun 07, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cant take pictures on webcam
  1. Double-click the HP Photosmart Essential icon on the Windows desktop.
  2. Select View>Get images>From Scanner. The Select Device dialog box appears.
  3. Select HP Camera and then click OK.
  4. A warning appears to indicate that the device isn’t a scanner. Click Yes.
  5. Click Capture to take a picture (snapshot).
  6. Click Transfer to save the picture in the My Documents/My Scans/<Current Month> folder.
Now you are ready to edit and share your photos with HP Photosmart Essential.
Apr 14, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
Epson Stylus Photo R220 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
